Jerry
posted Dec 15 '25 at 6:20 am
Hi,support
The temperature instrument records data every second. The customer wants to see the curve of the raw data (currently, only a 10-minute historical curve can be viewed). Is it possible to view a longer period of raw data curves without dragging the axes?
thank you
I created a printer called vtscada and configured it to print directly to a file, but when I use the "redirect" command to set it as the default printer, the program changes the default printer and crashes.
Redirect("DEF:","VTSCADA" { Select different printer };
If Local has a value of "DEF:", the value of this parameter has three elements separated by commas, as follows:
<printer
Glad the spam is being dealt with.
I've posted two similar requests but both were marked as spam. If they are being reviewed please post one or the other but not both.
I didn't intend to create a duplicate & my second was an attempt to get by support request into the forum.
Also, if everything is being marked as spam perhaps a message saying your post is pending approval would b
I've been really curious about writing scripts within an active VTScada application, but I'm not entirely sure how to go about doing so. I tried creating a new script tag, but I really do not know how to configure the tag. I tried creating calculation tags where I can bring up the function editor and even looked at the available options that function selection provides. I recently came across a Y
lxwang
posted Nov 26 '25 at 8:16 pm
After providing the correct user credentials, anywhere client is stuck on establishing connection & waiting for an available server. this connection is going through our F5 proxy.
Hi, I Cant download Light Version.
"There was an error trying to send your message. Please try again later."
Zihad
posted Nov 13 '25 at 3:40 am
I can not take data using JSON or XML Driver. I have made this link from Google Sheet. It always show 302 for JSON Driver and 1 for XML Driver
JSON Driver Link:
https://script.google.com/macros/s/AKfycbyphn30XSQYPcDdRzKcZ1_W7XnQwVYq95fQJraa9bzkkuB8_ErQFnLlFYYkyGU52j86AA/exec
XML Driver Link:
https://docs.google.com/spreadsheets/d/1zU-v9ubtb8QH7dm1CV4e8sNwpddIsjfTh4w5VUQtJsc/gviz/tq
I am working on my first project, coming from a different platform of over 10 years, all this is new to me. I have done searches without any results. I just want to know how I can change the background color on a "Page Navigation" widget. I have options to change the font, but I don't see anywhere that I can change the background color. Thanks guys! I am sure it's something simple that I am overl
I am trying to use twilio to call my guys on call for system alarms but i think it cannot reach the url because the thin client will not allow me to use port 80 or 443. how do i fix this?
I have an application that sizes a parameterized popup window to the right side of the screen, and scales it within a designated area. On the Anywhere Client the scrollbar that automatically appears automatically scrolls to the bottom upon the parameterized popup page opening. I wanted to see if there was a way to automatically scroll it back up to the top or prevent this behavior to begin with.
We like our SCADA pages with control pushbuttons to open with no objects selected. This way, if someone presses enter by accident they won't start or stop any equipment.
What we used to do was create a 1x1 pixel momentary button, link it to an Analog [Calc] tag named null which doesn't do anything, then layer the other objects which be clicked on in a way that this momentary button is select
Siemens LOGO! 8 programming and software setup help!
I have a LOGO! 8 Pure (no Screen) 230RCEo, 6ED1052-2FB08-0BA0
which has a DM16 230R 6ED1055-1FB10-0BA2 connected to it.
I have LOGO!Soft Comfort 8.4 control software however I cannot find my devices in the list of units in my Network View. So currently i have a LOGO! 8.FS4 setup as a google search stated this is what i need to setup for
Hello everyone,
We are planning an upgrade for one of our older site servers running a [mention your specific platform, e.g., Vantage, Citect, etc.] Historian. The machine currently uses a standard SATA hard drive, and we are looking to significantly improve data access times and overall system responsiveness.
We have identified a https://serverorbit.com/solid-state-drives-ssd/sata-6gbps-
I would like to set a property on a context tag, say "PLCDriver", and it's value be "[PLCPORT01\PLANTPLC01]", which I can do.
In the children tags, that need to access the i/o, I'd like to use that value to get a driver.
If I enter \PLCDriver in the Edit Parameter Expression, it retrieves the value, but says --Missing--
If I select the same through the tag browser, it works as expecte
I have a MicroLogix1400 connected directly to our SCADA server utilizing the TCP/IP port of the PLC. I'm having some problems in setting up the driver and port tags. I've only had some success when using the older tags, but wanting to learn more about the Rockwell Driver tag. The port tag was easier for me to setup than the driver tag. I've pointed the connection TCP/IP Name/Address as the IP of
I am connecting to the network for the first time in order to build a demonstration model to present as VTSCADA's suitability for our new SCADA system and I am having an issue with connectivity which I did not face with Ignition.
I am attempting to connect to a Micrologix 1400 plc, my server is set as my laptop, in the TCP/IP Port page I have entered the network IP address and TCP/IP Port num
J_Hob
posted Oct 2 '25 at 2:52 pm
I have created a HTML report page that interacts with my VT Scada application historian.
Does anyone know of a way that i can link my HTLM file (local to server) to a widget or screen?
e.g. Push button that opens the HTML.
Thank you in advance.
Joe.
I wanted to ask, can we still connect to the OPC UA Server or SQL Server (which is the VT Scada Server where tag history is stored) with the runtime licence only? I have heard software like XLReporter run with VT Scada without the needed Development Licence.
I know VT Scada stores data in its own historian, but is there with just the runtime licence - we can configure the Scada project to sto
gina
posted Sep 30 '25 at 8:04 pm
Hello, I was trying to pull data out from my MS SQL to VTSCADA and shown in a table form.
I do have a few tags that can pull the data out.
but it's kind of not making sense that i need to make a tag for every single cell.
i think there must be a way i can pull out a bunch of data into a table view by a single query.
How can I do that?
I'm a new user of VTScada and currently installed a VT light version. I want to setup Enron Modbus Communication with a RTU to read historical archive of the device. I need Technical support to setup a Enron connection in VTSCADA and how to read historical data and how to trace the communication to verify Enron query and responses?
abedig
posted Sep 26 '25 at 9:26 pm
I am setting up an integration between VTSCADALight and the Azure Event Grid MQTT Broker. I have provisioned a certificate and an Event Grid namespace, and demonstrated using MQTTX that I am able to connect with the certificate from my host to the Event Grid's MQTT Broker and send messages. Doing so requires specifying mqtts:// as the protocol, 8883 as the port, and using the SAN value
I'm needing to do an HTTP POST to a web server from VT Scada, which will reply with a JSON response.
From what I can see, the JSON/XML driver is read only, not write. I.e., can do an HTTP GET, rather than a POST.
I see there is a function called HTTPClient.HTTPSend(). How would I be able to use this function so that it operates in a similar way to the JSON/XML Driver?
Has anyone done
I need a safe way to stop multiple VTScada applications unattended and the VTScada Application Manager (VAM) on a monthly schedule to allow OS updates and a full system backup without risking application damage. Applications are already set to start upon system startup.
Pol
posted Sep 22 '25 at 8:19 pm
For a new application i need to connect VTScada with a MS-SQL database. I create a project with VTScada and i connected with a MS-SQL Database, i check the communication and all is perfect. I can write digital, analog and discrete data types tags from VTScada to MS-SQL Database. The problem i face is that i can't write string data type tag, e.g a name. Could you help me?
I've connected to a local OPC UA, can browse the nodes and have imported a tag. In the tag properties, if I select the tag helper OPCUA button, it shows the current value of the variable.
My problem is it doesn't show the value either in the tag list, or when drawing the tag.
I'm afraid I've missed something, but I just can't find it.
Thanks in advance
I want to animate a pie. My plan is to stack a white circle, then a yellow pie for power, then a small white pie, and another small colored pie on top of that so I can see how the generator speed is layered on top of the power output.
However, I don't see how to bind these things to the pie shape.
Or is there a way to color the arc meters in the gauges?
Dear Community,
I have micrologix 1100 PLC and VT SCADA Light Version. I had communicated both SCADA and PLC. Now, I want to send logs over UDP protocol to the syslog server. i need help and step by step guidance about this.
Secondly, I want to know where VT SCADA light version stores the logs on the PC and how I can enable VT SCADA to save the logs at specific path.
Need your help pleas
rachan
posted Sep 16 '25 at 7:41 am
I can't connect MQTT with Vt scada,It shows value 260 at the TCP/IP Port and Value 9 at the Mqtt client driver.I using HiveMQ and I already tested sending values withs HiveMQ as the host to Node-red,Which works,But when sending to Vt scada,the coneection cannot be established.How can i solve this problem
Maiza
posted Aug 30 '25 at 1:49 pm
I need to average one point on the graph to another, without exporting all the recorded content, only the selectable content. And I need to export it via Excel. How do I do this? Is there a method?
I need to average just this one pen that is circled:
Maiza
posted Aug 9 '25 at 7:03 pm
I have a device that receives information from a sensor. The sensor information is displayed on a graph. At certain points on this device, the variable becomes negative and resets to zero. How can I exclude this negative and reset variable from the graphs so that it doesn't apply to the invoice, since it makes no difference and will end up interfering with Excel exports? (Customer request)
