579
2.03k
30
247
Im trying to use VTScada to poll a Single array from an MQTT Broker. Once i get the tag into VTScada, I want to have the ability to break it apart into its individual tags and im wondering if this is possible or if anyone has done something similar yet??
The length of my array will be around 30 Dint Values. and i want to be able to view each value individually in VTscada after polling the sin
739
I want to make a new page where Sign in Button/Widget placed in the center of the page, apart from at the right top tab given in the VT SCADA as attached image.
It will be also best solution for me if I can move that "Sign in" button to anywhere respectively X/Y coordinates with Height and Width in the new page.
Or else, is there any property or widget or script, through wh
623bfd85a6386
168
prafull posted Feb 21 '23 at 4:10 pm
I am trying to test the REST Queries .
I have set the application property "RESTAllowedOrigins" to null as given in your example HTML page.
I get TypeError failed to Fetch at the bottom of the page (in Red colour)
Anyone has experience with this REST API Queries?
Any more tips, examples etc?
It's quite frustrating when it doesn't work and we don't get the results as pe
recent by mahin101  ·  Jan 31 '24 at 9:49 am
165
What I am doing:
Cast(
Concat(
SubStr( [Prod_End], 0, 4), {2024}
SubStr( [Prod_End], 5, 1), {1}
SubStr( [Prod_End], 7, 2), {20}
),2)
This will output 2024120 to a analog calc tag, that i will use in reporting. (I need analog type because other tags are also analog; but thats not the point)
Problem:
You can see the picture that the formatting is not foolproof. This calculation will
65ac93e4181c2
287
TLDR: What is the proper way to ‘wait’ for HTTPSend function to finish its entire api call? The function's url parameter changes from a droplist widget.
I have been testing different ways to run the httpsend function. In the script block of ‘main’ module, in a called module, and as a launched module.
Goal is to change the api link according to user prefer
657fe56f1ada9
recent by Kevin Way  ·  Jan 12 '24 at 3:29 am
134
hilldc posted Jan 11 '24 at 8:52 pm
Currently have two port tags setup for a lift station ... one for cell ... and one for radio. I would like to be able to switch between the two with a selector switch on a page. Possible or not? Better way? Thanks
recent by Kevin Way  ·  Jan 12 '24 at 3:00 am
189
I need to come up with valid expression for two lines of text with a carriage return & line feed separating them. I've done this before but I can't remember where or how. This shouldn't be impossible to find in the help. I know it's in there somewhere but nothing I search for turns up anything useful.
By the way, I am aware of VTScada's multi line text widget. That widget doesn't let
565
Hello, I'm trying to figure out the process for retaining historical trend data during a hardware upgrade, where I am also upgrading the VTS version.
I've found information stating to copy the directory over from the old PC to the new PC, but it seems like I may need to install the same version of VTS on the new machine, then upgrade to the newer version, and I would like to be able to do so
242
I am trying to create a TAG context for a group of Modbus tags.
my data type is IEEE Double Precision Floating Point (8 bytes), and I need to write an expression for the TAG address so that the address will change by the meter number;
Meter #1:
TAG1 address: 31001/Double
TAG2 address: 31005/Double
TAG3 address: 31009/Double
Meter #2:
TAG1 address: 31021
126
jroc11 posted Dec 15 '23 at 1:52 pm
So I've had a pulse rate tag that's been pulsing and working fine for the past few weeks with zero issues. Now all of the sudden its reading as a zero for the pulse rate. This number will fluctuate from outputting a zero to outputting the correct number at its own will. Has anyone seen this before? I feel like this could be a possible bug on VTScada's end?
206
hilldc posted Dec 11 '23 at 1:32 pm
Fairly new to VTScada and I need help setting up certain tag to pull from a weather station (Columbia 420) we have.
The station keeps a running total up to 10 inches before rolling back to 0 inches. I would like to display rainfall today but the reset back to 0 has me stumped as to how to setup that tag to account for the rollover which could happen in the middle of the day.
Thanks in ad
recent by cardsfan  ·  Dec 13 '23 at 1:02 pm
278
jroc11 posted Dec 5 '23 at 4:22 pm
Im currently trying to find out a way that i can make a digital tag that goes from on to off and off to on every 15 minutes or so. Is there any suggestions on what the best way to do this is. I will be pairing this tag with another one in an expression to trigger a multi write tag every 15 minutes while the day is between certain times. Any suggestions help! Thanks
389
So i have an analog calculation tag that is logging data based upon the whole day. i need to to grab two values from this day, these values are from 6am- 2pm and 5:15pm-2am. What is the best way to do this? i have tried using totalizers, logging tags, triggers, history stats, but no luck. I have two digital tags setup for each shifts. They output on or off depending on if the current time is in-b
recent by jroc11  ·  Nov 30 '23 at 4:42 pm
1 ... 78910111213 ... 29
