579
2.03k
30
211
Caltabiano_Angelo posted Jul 3 '19 at 9:28 am
Good Day Support Team,
Few months ago i built an application running with ModBus communication. On the laptop i made it, it works like a charm.
Then i've installed VTScada on another laptop, and import the project that was on my persoanl laptop on this new one.
i set up the fixed IP address as suppose to be, but i have no communication at all. I can PING the IP of the PLC, so it means
96
dw2white posted Jun 21 '19 at 1:07 am
Hello, I am evaluating VTScada for our facility and am working with the scadalight. I have not worked with Omron Plcs in many years and need some information.
My plc has some levels which are stored in a data area (ie D0700). The PLC resides on our network (ie 192.168.10.20). From the program, I do know they set the port to 2120 instead of the default 9600. I am not sure which settings to use
144
I can successfully pull up the data into Excel using ODBC connection. The SQL statement like
select * from Alarms;
is working perfectly fine. The issue is when I use 'where' statement, I get an error. The following command is giving an error.
select * from Alarms where Active = 1;
OR
select * from Alarms where 'Active' = 1;
OR
select * from Alarms where Active = '1';
122
I would like to know if there is a possibility to get the real-time information of the alarms that arrive in the system, via ODBC, a list of the alarms that arrived in a certain period of time. I've tried to understand the file alarm.db and Alarm.LOG, but it seems illegible to me. Can someone help me?
recent by dougs  ·  Jun 10 '19 at 12:11 pm
336
Hussain posted Jun 1 '19 at 1:19 pm
Dear Dave, Thanks.
Do you mean thru realm we can authenticate other users from same network? if yes then please forward the link to install odbc driver again, the one you sent is not working.
As I know ODBC is to link with third party like xlreporter.
but is it possible to run the application it self from the remote laptop? How, is it thru OPC client and server configuration? is it
452
Hussain posted May 31 '19 at 1:35 pm
Dear all,
I have installed VTSCADA light in a data logger (windows operating system) and link the logger to controller (modbus device) thru rs232.
Is there any solution to access from remote laptop?
Is ODBC or XLreporter provide this solution? is it free or at least demo for testing?
regards
Hussian
667
Having issues connecting to Siemens S7-1500 series PLC's using the Siemen's driver. I have an Allen Bradley unit that is working so I know my network and server is working.
Any help or examples or templates would be helpful. I am a PLC specialist looking at purchasing a entire system but want to get a real-world example to get approval to buy.
5ccc68deb73a8
recent by dougs  ·  May 3 '19 at 6:13 pm
144
I'm not a SCADA expert, but I want to know if is possible connect a WirelessHart gateway through Ethernet/IP directly to VTScada (without PLC).
The OEM of the gateway said that the WH devices are made available to the host systems via instrument list. This list contains one or more I/O cards. Every I/O card has one or more channels. Up to 6 field devices can be connected in multidrop mode to
215
markp posted Apr 1 '19 at 12:25 am
When I RDP into the VTSCADA machine the window only fills half of the screen and cannot see the whole application. I can open other applications they work correctly and I can see the whole window. I don't think it is a RDP issue. Any thoughts?
585
14
patrick.lelievre.2@gmail.com posted Mar 12 '19 at 12:36 am
I've tried 6 times to install VTS 11.3.23 yesterday on a Windows 10 Pro PC. I've attache my PC Systeminfo.
1- First try, I download the executable from the VTS web site, right click and run as an administrator. I've selected the VTS Light version 64bits. The installation freeze and the whole PC. It freezes at 15%, and I went for lunch before restarting the PC. The PC did not
5c86fd97e5430
155
dgonsior27 posted Mar 6 '19 at 5:49 pm
So...I have two report tags reporting 15 analog inputs on a standard style report, outputing to a CSV file in a folder on a server. Custom preset at 1 second duration, and 1 minute end time. The report tags are triggered daily at 1:55pm, and 4:55am. The reports successfully generate but only with time/date information and analog input tag names...no values. Any ideas on where I might be going
540
Hi all,
I'm trying to connect to a TCP modbus server running on the same machine as the instance of VTSLite. I've confirmed the server is operating (with a different client), but I can't seem to get my VTS application to write or read any addresses.
I've followed the process here to make my tags, using "localhost" as the IP address and the same port as my server (standard 502) https://ww
5c59f0d18bd61
