I'm trying to use a C# based dll with my VTScada application. To do so, I'm using The function DLL.
It's working well with integers, floats and strings, but I have to do some gymnastics to get a bool (I use an integer return type and apply a modulo 2 to the variable to get a 0 or a 1), and I flat out can't get any types of object. I'm trying to use a pointer as a return type but I al
Custom Colors
Hi. Here is my MWe:
documentclass [12pt, Dvipsnames] {Amsart}
usepackage{latexsym, AMSSYMB}
usepackage{xcolor, COLORTBL}
begin{document}
{color{orange} $ varphi (x) $}, {color{RedOrange} $ varphi (x) $}, {color{red} $ varphi (x) $}.
end{document}
Now, I'd like to darken the second orange, but I can't
To create my own custom color. So, I searched for a
Hi All, we are looking at a project where we want to host VTScada on a remote AWS web server and have it amalgamate several remote well sites connected to the internet with GSM modems. Has anyone deployed a system like this with VTScada before? We've done similar with other platforms but we're keen to move forward with a VTScada solution for this one. Any tips or info is appreciated!
I am test driving the lite version. I am struggling to find clear "go here do this" document to connect this to a server SQL database. As anyone done this with lite?
Good morning,
I am currently working on a VTScada Light License with the goal of being an historian and data collector for a wastewater treatment pilot unit. I have come across the following issues when it comes to exporting/reporting:
What I can do with the HDV:
Export data for a specified unit time frame (ex: 2 days, 1 week)
Export "Time Per Record" to record every X minutes/seconds
I have the latest Light software. Up and running connected to a Compact Logix running V20 flawlessly. But with my V.28 Control Logix, it will connect long enough to show the connection in the AB Demo driver then disconnects. what can I try?
Andreas
posted Apr 5 '18 at 9:01 pm
I am quite new to this scada but i like it.
I have a customer that wants to use a ABB AC500 (modbus TCP) for waste water application. He wants to store the last 7 days of overflow water from the station and to read this data if it is missing in the historical data in VTScada.(if there has been a communication error)
My programing data is as follows.
At midnight all data moves one
Does the Scada PC require RSlinx to provide a Comm. path to the PLC?
JustinW
posted Mar 14 '18 at 11:20 pm
Is there a way to change the color of the text based on some set-points for data coming from an Analog Status tag? I'm thinking you would use the "Text Change (4 state)" widget, but I can't figure out how to set the values for the different states.
For example, I would like it to always show the tag value, but change from blue when it's below 110.0 to green between 110.0 and 120.0, and red
Victor
posted Mar 12 '18 at 7:35 pm
Is it possible for each server/station of the same VTScada application to have their own Alarm DB and Event DB?
Or is there any way so that alarms would need to be acknowledged independently on each server/station? So if an alarm is acknowledged on one server, it still shows up as unacknowledged on the other.
Thanks
Victor
I'm trying to save a report group (Save Group), with a name, but the OK button is always greyed out, no matter what tags/report types I select. Same if I use a Report tag.
Regards Mattias
Hello, can someone please take a look at the attached screen shots and let me know why there are no values for the tags "T_Room" and "DI4"? I'm connected through a USB to Modbus RTU converter. The TX and RX lights are flashing on the converter, so I know its talking to the PLC. The first four screen shots are from the PLC software. I not sure how the scaling should be set up for analog status
I was wondering if anybody knows of some revenue grade power meters that are able to communicate with VTS. Meters similar to the SEL 735.
Thanks,
Aaron
I was wondering if the following power meter would be able to communicate with VTScada.
https://www1.itron.com/PublishedContent/100196SP-08_SENTINEL_Multimeasurement_Meter_web.pdf
Are there any drivers that could work with this?
Aaron
I have a custom page I need to be only accessed by superAdministrators.
In order do do this, I created an application privilege and added it to the required security privilege of the page. Then I added the application privilege to the superAdministrator role.
Now I would like to hide that application privilege from regular Administrator to prevent them from managing that privilege.
I'd like to add a vertical scrollbar to my window so I can see the elements outside that window scope. I am able to display the scrollbar using VScrollbar. As I understand, VScrollbar returns a numeric value representing its position.
I tried using WindowOptions to make a vertical translation equal to my scrollbar position to no avail.
Could you tell me how to properly use VScrol
HI,
I'm thinking about changing vehicles, I currently have a Xsara Picasso Gasoline 90 Cv. I want to buy a C4 Picasso Diesel, I think the one that better fits me is the 110 HP, but I have the doubt between the manual change or the CMP, I have heard some comment, about the latter, and I have doubts. Can somebody help me????
Thanks
I did not find the right solution from the internet.
HI,
The multi instrument software displays most of the signal parameters and also perform the data logging.
We have the enquiry to get some of the parameter values (THD & SNR) in our SCADA.
Is it possible to do the same by any means - say any protocol or via pc communication port we can exchange data ?
Please do let us know , as customer requires some data logging in his SCADA of
We are installing VTSCADA for the first time in our district and will be setting it up on two Windows 2016 Virtual Servers. Is there any documentation I can give our IT contractor for setting up these servers for running the HMI?
Hi, Is there a way to edit the alarm set point for Analog Status Tag without accessing to Tag Browser? I would to set up a Numeric Value Widget for alarm set point on Page in order for user to edit if they are unable to access to Tag Browser. I tried to set up a Linked Tag Widget but unable to select property tag after configuring according to the guide available.
Your help is greatly apprec
I have configured VTScada as a SNMP agent and generated a MIB file from the application. I have followed the SNMP agent configuration according to the following steps:
SNMPAgentEnable Value = 1
SNMPAgentIPListener Value = SNMP IP Listener Tag
Create SNMP Agent Widget on Idea Studio
Generate MIB file
Load MIB file using MIB browser but unable to GET any values
Is there a solution to resolve t
Maxime
posted Feb 1 '18 at 3:59 pm
I am new to VTScada and I am testing out the scripting potential of the platform.
I started out by creating a widget that display my typical dataset linked to tags. To display that widget I used the GUITransform function.
Now I obviously don't only have one but many of those that I want to display on the same screen. Also the number will change dynamically so they will h
I'd like to use an array of tags and order it by different characteristics in script (ex. the tags with an active alarm first).
I think the best way to achieve this is by using the function GetTagList then sort that array. Unfortunately GetTagList only return an array of tag names so I can't access the tags properties. In order to sort them I would need a function that return a tag p
The latest version of Chrome (64.0.3282.137) on Android (7.0.0) doesn't seem to allow you to logout of the VTS Anywhere client (VTS version 11.2.10). We use to be able to tap our name and the menu would pop up and give you the option to Log Off. Is there a work around to get this working again or is this working in the latest version of VTS.
Glenc
posted Feb 1 '18 at 5:36 pm
I am very new to SCADA we are using the vtsx client to connect to the server. On some of the Windows 10 desktops when the URL to the server is typed in the program automatically adds :80 to the end and will not connect. i.e. the url is http://15.15.15.15 as soon as we hit connect it shows up a http://15.15.15.15:80
The service is running on port 80 on the server.
These computers DO
ICI
posted Jan 11 '18 at 2:22 pm
Missing or damaged file in repository.
Trace Item GUID 7c75a5c9-858a-4e7b-bd34-0e563c453ea0
Timestamp Thu Jan 11, 2018, 09:07:19.714 (Eastern Standard Time)
Application Unknown
Caller System\Repository\Init\GetManifestRev\ReadManifestRecord
User ID
Victor
posted Jan 9 '18 at 7:47 pm
In the Programmer's guide document, there is a "A 15-Minute Snapshot Report" section that show you can use the \SnapshotReport function to create a custom Snapshot Report. Is there an equivalent function for total report that also allow custom time frame?
Thanks
Windows 10 update KB4056892 prevents the VTScada Internet Client (VIC) from being launched using the VTSX desktop program on client computers with that update installed. Other VTScada Thin Client formats, including those for all mobile devices, are unaffected (see work arounds below).
Microsoft is aware of this issue (see notes about CoInitializeSecurity at https://support.microsoft.com/en-
jsanden
posted Jan 4 '18 at 9:22 pm
How do you control how often the plot data widget updates? It's fine on the local machine, but the internet clients have a slow connection. The plots show "data retrieval in progress" more often than they show the plot line. I'd like to slow it down specifically on the clients, but would be OK setting it slower on the project if that's the only way.
jsanden
posted Jan 12 '18 at 9:24 pm
I have a client that likes the "arc" gauge widget. I can't figure out the decimal formatting on that one. Some tags display a decimal, while others show a whole number.
Some of the gauges let you specify the number of digits to display after the decimal. How can I set that on the arc gauge? Is there an expression to use?
