186
hewkyle posted May 4 '21 at 3:35 pm
Good morning,
I am seeking additional resources, experience, or advice for integrating an Inovonics EN4080 IP gateway and associated equipment into VTLight.
Software:
VTLight
BQT BACnet quick test
Hardware:
EN4080 - vendor ID 1093
EN1235D
Network:
Locally connectivity between my laptop and the IP gateway.
Some examples of how the hardware should be structured in
recent by hewkyle  ·  May 20 '21 at 9:52 pm
82
I need to display a history statistics tag in the runtime &, when the operator clicks on it, open historical data viewer to open up & display that history statistics tag's source.
I was able to do this but what I came up with feels too clumsy.
I've created a group of display widgets with pop-ups disabled in the history statistic tag, with pop-ups enabled in the I/O & calculati
recent by Michael  ·  May 17 '21 at 5:33 pm
74
Brent Saunders posted May 11 '21 at 4:32 pm
We want to export and sync the VTScada tags to our dnp3 outstation database. We set up an odbc datasource and tested the connection with success. However when we hit "Export", we get "Operation Failed" at the bottom of the window. Any clues?
277
Ketul posted Mar 26 '20 at 12:53 pm
How can I make rotation in any shape.
For ex. I have draw one fan symbol in idea studio.
I want to rotate this shape in clockwise direction.
How can I do this in VTScada.
Please guide me through steps to rotate any shape in VTScada idea studio.
53
What's the best way to display a History Statistics (HistStats) tag to 3 decimal places?
I setup my HistStats tag to calculate a rolling avg from an instrument reading. It's doing what I need except It displays the results default to two decimal points & I need three.
When I bring up my HistStats tag's properties and go to the Display tab the only option there is a place to link to a
444
The VTScada Red Bell can be turned off on the server, but the VIC clients and Anywhere Clients are still showing it. How do you get the same behavior out of the clients that you do from the server?
I turned off "Show Alarm Indicators" in the application configuration / Title Bar Contents. And it is gone from the Server but not the clients.
Any help would be greatly appreciated!
99
martin200261 posted May 5 '21 at 2:59 pm
The organisation I'm currently working for use measured data in offline models to produce predicted (forecast) data for the parameters we monitor.
Can VT Scada handle importing data with future timestamps? and can it handle multiple predicted data datasets?
137
I created an additional Alarms Page using an Alarm List widget, and it allows me to filter the System Event DB out, but that pesky Alarm Icon at the Title Bar is glowing and offers to take a User straight to the Original Alarms Page where they have access to see all of the System Events.
Any way to stop that on one front or the other?
I have even used SecurityCheck to give Developers visi
79
martin200261 posted May 5 '21 at 2:55 pm
I’m hoping to integrate VTScada with one of the Azure data store products as the historic data archive, has anyone done this before?
My fallback position is to use MS SQL in Azure but would like to use Azure Data Lake or Azure Data Explorer
66
tmills10 posted Apr 29 '21 at 8:44 pm
I'm just testing some comms on the bench here for a customer. I can set up the DF1 tags fine and get good comms and data when set to TCP/IP, but when I try to switch it over to the serial comms I get an error code 16 Illegal Command or Format. I can see on my SerialPort tag I don't have any errors so it must be something in my DF1 driver tag I'm missing.
Thanks!
47
Ketul posted Apr 29 '21 at 6:32 am
I have created one context tag named it as "MRD455" and description as "MRD455 Testing". Then it displays its Description name on the sites overview main page by default.
How can I display the actual site name on sites overview main screen.
I want to see MRD455 (site name) on sites page. HOw can I do it.
608a44cad2bad
177
deshydra posted Apr 26 '21 at 3:08 pm
Need to send an alarm acknowledgement over MQTT, is there a way that I can read the status of an alarm to send; or can I look at the canned ack button and send after that has been pressed? I just need something to trigger a write message.
141
Basically i have a Total Volume Tag I want to snapshot it into Current Month and Previous Month Calculation Tags on the 1st of the month at 8am.
Volume = 1000
Snap = 500
Cmonth = Volume - Snap
At the rollover time move the Cmonth to the Pmonth
and then move the Volume into the Snap.
Does anyone have any good ideas in how to do this in VTScada?
Thanks,
recent by Kevin Way  ·  Apr 15 '21 at 5:38 pm
203
Jeff.Hohnstein posted Apr 14 '21 at 5:22 pm
When using a Zoom modem for alarm dial-out, I am getting a SAPI Error: 0x8004530A when attempting to call out. I have downloaded the correct driver from Zoom, checked the registry settings, set my area code and run the diagnostics on the modem (every was normal). Any thoughts?
Solved - We had the modem installed on a rack mount server running Server 2019 with no sound card.
188
rizki.muhammad.setiawan posted Apr 12 '21 at 7:05 am
Dear Sir,
our client want to pool data from VTScada server,
the VTScada already have OPC server license,
they want to pool data from another computer,
is there any tutorial / guide?
we already try to read the documentation, but still not understand,
where we create the Opcserver tags? is it below the driver / port tags?
for example server and client user windows 7, whats sh
303
Ketul posted Apr 12 '21 at 11:40 am
I have created one IO calculation tag (analog) that shows the value of PUMP RUN TIME in the second.
Ex. Let say I got a tag value as 3600 seconds.
From this tag, I need to show PUMP RUN TIME as in format 01:00:00 (hour:minute:second).
If the value is 3720 I need to show it as 01:02:00 (h:m:s)
If the value is 3750 I need to show it as 01:02:30 (h:m:s)
How can I show that?
159
Trying to input an analog value in a numeric entry box with 1 decimal place and publish over MQTT. Everything works fine but if the data entry is done wrong (entering a .xx value) the publish fails on the receiving PLC end. I limit the numeric entry box to 1 decimal and it displays properly in the the box (enter a number xx.xx and only xx.x rounded up is shown), but in the MQTT world as soon as E
196
Ketul posted Apr 5 '21 at 12:07 pm
I have my DNP3 protocol XML file that includes Digital inputs, Digital outputs, Analog inputs, Analog outputs, Counters, etc.
I need to parse this data to VTScada and I need that VTscada generates tag accordingly.
How can I read the XML file into VTScada and end results that VTScada automatically generates the tags in Tag browser?
How can I do that?
277
garrett.crowell@emailsas.com posted Nov 3 '17 at 3:52 pm
Is there any way to rename a type? I can't figure out a way through the application configuration or through export & sync. I have tried exporting and changing the name on the VTS_Reserved tab and deleting the export info and data fields but that didn't seem to work.
Alternatively, is there an easy way to make a copy of a type?
Anyone have any ideas?
recent by Vadim  ·  Mar 11 '21 at 5:19 pm
389
8
I've an opportunity to install a new SCADA system, but prior to quote the job, I wanted to test if it's working.
I've a RX3I CPU331 and I've installed (latest VTScada version 12.02 on a Windows 2019 server. I add the GE Driver configured has shown in the picture with the default port founded in the help file. I add 1 analog points %R606 which is a level moving in the PLC, but i don't
60415302d0683
157
Can anyone tell me how to launch what VTScada call the "CIP Address Select tool"?
All I can find in the help is this reference which tells me it exists but there is nothing here about how to open it.
https://www.vtscada.com/help/Content/D_Tags/Dev_CIPAddressing.htm?Highlight=VTScada%20CIP%20Address%20Select%20tool
The help says this tool is "... found in every I/O tag that uses the CI
recent by mike_yung  ·  Mar 8 '21 at 6:58 pm
