252
CharlesH posted Jan 15 '20 at 6:17 pm
We are preparing to upgrade our software from 11.3 to 12.0+ and I am looking for any information that we need to know before upgrading? (i.e. are there any windows updates that don't play nice with VTScada v12?, any major changes we should prepare for going from 11.3 to 12?)
Also, as a secondary question, is it possible to launch our application on a different PC/Server and run it as if it we
150
Mrpike posted Jan 14 '20 at 4:34 am
What is the best/easiest way to manually disable comms to a device that is missing? I have devices that are offline at times and I want to optimize comms by preventing the driver from trying to constantly attempt comms to a device that I know is offline. Is there a setting I can toggle? Thanks.
99
drummin89 posted Jan 14 '20 at 12:23 am
I believe I know the answer to this but figured I'd ask anyways. Is it possible to do a lookup table in VTSCADA?
I have a customer that wants some live calculations done that are currently done in an Excel spreadsheet, some of which involves a lookup table.
Even if I have to do something external and pass the result back into VTSCADA. Can VTSCADA read from an Excel spreadsheet through scr
142
dbabler posted Jan 9 '20 at 1:59 pm
We have 4 computers on the same network at a single location, none of them have internet access and the times on the computers will tend to float away from each other. Is there a way to sync all 4 using VTScada somehow? Basically just need to have one common time across all stations if possible.
199
Kevin Way posted Jan 2 '20 at 8:42 pm
I am looking for some direction on creating a Data Grid in VTSCADA
that can poll from the historian.
There is an example in the Oil & Gas Suite for the flow computer history.
Any help would be appreciated
5e0e558d35030
165
I have a device that sends status updates on a Modbus network. I have successfully connected to it and can access the registers. However, there is a status register that stores the system status as an integer that I need to decode into a binary word. I then need to be able to access each bit of the word to determine the system status. How can I accomplish this? I'm new to working with SCADA and t
recent by Mrpike  ·  Dec 31 '19 at 2:58 am
187
drummin89 posted Dec 19 '19 at 8:14 pm
I have some data points that I need to put in a report, but I only need to show those values every 15 minutes that the process is in a certain step (A pump is running). The report will be ran at the end of the month and will cover the entire month.
I would prefer to have those points logged continuously for trending and so the customer can look back at any time and see what the value was whet
recent by drummin89  ·  Dec 26 '19 at 7:12 pm
194
dbabler posted Oct 9 '19 at 1:01 pm
We currently are looking for a possible way to compile all the exported data that is collected into a nice easy to read template, keeping it as user friendly of a process as possible. I myself am very new to VTScada so I thought this would be the best place to come, has anyone found any cool solutions to this issue at all? These are all water treatment facilities so they're primarily use X amount
154
Mrpike posted Dec 17 '19 at 3:10 am
Hi community, is there a way to clear the logged trend plot line data. I want to keep storage on the host pc to a minimum and do not want this file to get too large. Keeping data for a long time is not a priority so I would like to delete the logged data periodically. Thank you.
377
Ketul posted Dec 19 '19 at 8:24 am
I want to send a SMS of generated faults/alarms from SCADA on mobile number through AT commands. I have connected westermo MRD-455 4G cellular router to scada workstation PC by serial to USB port.
How can i configure tags in scada for modem configuration and to notify SMS on my mobile number.
Can you please guide me through the steps to configure modem tags in scada.
142
Mrpike posted Dec 21 '19 at 2:08 am
Hi community. I am trying to use a calculation tag to determine the bit status of an analog value. I cannot seem to get the syntax correct to put in the expression. I found the code snippet below but I think that may be for scripting not expressions...not sure Is there any documentation on functions and syntax for these expressions? trying [value] && 4 does not work to find the statu
5dfd7df070c36
recent by Mrpike  ·  Dec 21 '19 at 3:27 pm
243
9
Hello vt scada community. New user here. I am looking for assistance to create several digital tags based off the value of a single Modbus register. For example, register 40001 value =1 is "pump running". Same register 40001 value =2 is "pump stopped". How can I accomplish this with minimal tag usage? Thank you
recent by Mrpike  ·  Dec 19 '19 at 8:54 pm
278
I need to create a report that will display the lowest value that a tag registered throughout an entire day, along with the time that occurred. On top of that I need to display this information for the entire month.
I really do not know how to approach this at the moment.
I thought about using the standard report type since I believe it dumps all the available data into the report, and th
recent by drummin89  ·  Dec 19 '19 at 4:51 pm
222
CharlesH posted Nov 22 '19 at 4:48 pm
Is it possible to build a tag that can determine the elevation of my facility based upon the coordinantes in the parent site tag?
Or is it possible build a widget that references the Long. and Lat. of the parent site tag to determine site's elevation?
Thanks in advance!
295
Programming question:
I'm using an Analog output (VTS Datatype) writing to a PLC DINT by way of a "Numeric Input" on the page to allow user to enter a passcode (EQU in PLC) to permit the action of a selector switch, right below the numeric input box.
When you enter the correct number, "it is retained in the VTS tag browser" and will work okay. But I need a way to clear it out after a minu
recent by ADubberly  ·  Dec 12 '19 at 6:32 pm
116
It appears as though you cannot pass a Universal IO - String Calculation tag configured as a string to a Script tag.
Changing the Universal tag to a Numeric Calculation, but keeping the value as a string, works just fine, the Script is able to use the parameter's string value. Downside of this is that the value of the tag does not show in the tag browser.
As well, using the legacy Calcula
recent by Michael  ·  Dec 11 '19 at 4:38 pm
143
Serv-atron posted Dec 10 '19 at 9:57 pm
I have a 4 position switch in the PLC
I need a 4 position switch to write to the PLC from Trihedral ver 12
so that it is not maintained and will match the one in the PLC
I assume I need a widget to provide an analog out to write a analog value to the PLC but I am not sure how to do it.
Can anyone help me here?
112
drummin89 posted Nov 27 '19 at 12:42 am
Can someone explain how to make a copy an existing application. I want to try different settings but don't want to screw up my current application.
When adding an application using the advanced option, I would think that I would want to clone from Changeset but then it warns to not re-install a changeset if the application still exists on this or another server.
64
morgan1 posted Nov 21 '19 at 5:17 am
I have both a hp printer and a scanner. My printer's USB port has been damaged so I decided to connect my printer with a wireless connection. It wanted a WPS pin on hp printer at that time and I found the pin after searching many websites and then connected my printer. But after that, my scanner stopped working, I tried a lot to solve that problem but failed. What should I do now?
88
dougs posted Nov 19 '19 at 8:42 pm
Just a heads up that Excel has a limit of 31 characters for table names. This means that if you make a tag type with a name longer than 31 characters and export the tags to Excel, you will have a problem.
Excel will tag the tag type name and rename it to Sheet1. Or truncate it some other fashion. You make changes to the tags in that tag type and import the changes. Since VTScada can no longer
