98
If you seem to have lost your VIC graphics after accepting Windows build 1903, we are looking into it. As a workaround, stop the VIC. Open Internet Explorer and clear the cache.
Go to C:\Program Files (x86)\Trihedral, right click on the VTSX.exe and run it as administrator - even if you are an administrator.
Log in and run it once. Close it. You should be able to run it normally from your
254
dw2white posted Jul 29 '19 at 9:03 pm
I am working with an Omron Cj2H. Programmed analog inputs and reading into a DM. Positive values are performing okay, but as soon as I go slightly negative ( reverse flow), then the number jumps to 65535. This is telling me it is wrapping around. I have tried using negative values in the scaling, but have not been successful at this point.
I can watch the channel in the plc and it remains nega
217
DanW posted Jul 17 '19 at 9:33 pm
Hi, Is there a way to edit a Type property from the VT HMI? Some users will not have access to the Tag Browser but may be required to change IP address which is set up as a property of the Site Type. I tried several methods to set up a Linked Tag Widget but have been unsuccessful.
I'm thinking that I may have to script it somehow but want to know if I'm missing something before I go down that
recent by Michael  ·  Jul 30 '19 at 11:40 pm
151
graingr posted Jul 13 '19 at 5:51 pm
I am building a plant from scratch. The plant has different types of equipment and all I can see in VTScada are various pumps, valves, and motors. Has anyone built or have access to bar screens, conveyor belts, weir gates, or anything else that might be useful?
Thanks in advance!
206
Caltabiano_Angelo posted Jul 3 '19 at 9:28 am
Good Day Support Team,
Few months ago i built an application running with ModBus communication. On the laptop i made it, it works like a charm.
Then i've installed VTScada on another laptop, and import the project that was on my persoanl laptop on this new one.
i set up the fixed IP address as suppose to be, but i have no communication at all. I can PING the IP of the PLC, so it means
86
dw2white posted Jun 21 '19 at 1:07 am
Hello, I am evaluating VTScada for our facility and am working with the scadalight. I have not worked with Omron Plcs in many years and need some information.
My plc has some levels which are stored in a data area (ie D0700). The PLC resides on our network (ie 192.168.10.20). From the program, I do know they set the port to 2120 instead of the default 9600. I am not sure which settings to use
143
I can successfully pull up the data into Excel using ODBC connection. The SQL statement like
select * from Alarms;
is working perfectly fine. The issue is when I use 'where' statement, I get an error. The following command is giving an error.
select * from Alarms where Active = 1;
OR
select * from Alarms where 'Active' = 1;
OR
select * from Alarms where Active = '1';
192
Brandon Peay @ Fritz Winter posted Jun 12 '19 at 1:35 pm
I am trying to integrate in a counter and some automated resets. The plant is currently changing the times of shifts a lot and I would like to allow them to configure on the fly. Is there a way I can change the trigger tag using parameterization? If so I cannot find any information on the exact syntax or how to do so.
5d00f09b8bd5f
recent by Michael  ·  Jun 12 '19 at 5:06 pm
120
I would like to know if there is a possibility to get the real-time information of the alarms that arrive in the system, via ODBC, a list of the alarms that arrived in a certain period of time. I've tried to understand the file alarm.db and Alarm.LOG, but it seems illegible to me. Can someone help me?
recent by dougs  ·  Jun 10 '19 at 12:11 pm
334
Hussain posted Jun 1 '19 at 1:19 pm
Dear Dave, Thanks.
Do you mean thru realm we can authenticate other users from same network? if yes then please forward the link to install odbc driver again, the one you sent is not working.
As I know ODBC is to link with third party like xlreporter.
but is it possible to run the application it self from the remote laptop? How, is it thru OPC client and server configuration? is it
448
Hussain posted May 31 '19 at 1:35 pm
Dear all,
I have installed VTSCADA light in a data logger (windows operating system) and link the logger to controller (modbus device) thru rs232.
Is there any solution to access from remote laptop?
Is ODBC or XLreporter provide this solution? is it free or at least demo for testing?
regards
Hussian
664
Having issues connecting to Siemens S7-1500 series PLC's using the Siemen's driver. I have an Allen Bradley unit that is working so I know my network and server is working.
Any help or examples or templates would be helpful. I am a PLC specialist looking at purchasing a entire system but want to get a real-world example to get approval to buy.
5ccc68deb73a8
recent by dougs  ·  May 3 '19 at 6:13 pm
144
I'm not a SCADA expert, but I want to know if is possible connect a WirelessHart gateway through Ethernet/IP directly to VTScada (without PLC).
The OEM of the gateway said that the WH devices are made available to the host systems via instrument list. This list contains one or more I/O cards. Every I/O card has one or more channels. Up to 6 field devices can be connected in multidrop mode to
187
John_SBPG posted Apr 12 '19 at 3:49 pm
Here is my situation:
My current application has both my sewer lift stations and water towers in one application.
My water plant operators need to see only the water towers and hear alarms for them. But my sewer lift stations create an almost continuous stream of alarms. This had led them to mute the entire system.
Question:
Is there a simple way to turn of alarm sounds for my s
214
markp posted Apr 1 '19 at 12:25 am
When I RDP into the VTSCADA machine the window only fills half of the screen and cannot see the whole application. I can open other applications they work correctly and I can see the whole window. I don't think it is a RDP issue. Any thoughts?
