579
2.03k
30
251
I'm connecting an old Schneider Quantum PLC (311 10 controller ) ( 770 01 NOE card). I've set up the Port driver to read the PLC address 155.177.184.94 Port is 502 (I confirmed from the old HMI we were using that it is the correct port.) For the Driver I set to Modbus compatible device as per the VT Scada recommendations for that connection. I've left everything else standard as nothing looked o
recent by tturner7  ·  Sep 15 '23 at 5:48 pm
76
TomE posted Sep 13 '23 at 3:34 pm
Hi Folks,
Regarding the DrawHDV widget, is it possible to edit the options in the time span dropdown menu? I have a request to add 3mins to this as this is a commen time span for one of my customers.
Have done this quickly with a "Plot Data" widget, however it does not have the functionallity of the "DrawHDV".
Thanks!
232
I read I can turn off the splash screen & I'd like to do that.
https://www.vtscada.com/help/Content/p_Properties/NoSplash.htm?Highlight=NoSplash
Adding NoSplash = 1 did nothing. Neither did adding NoSplash on it's own without the = 1. Can someone whose done this confirm that it actually works? I don't want to bang my head against the wall trying to use something that's broken.
174
Pictured above, is an interval selection widget i created in version 12.1.25. Selecting each interval writes a value to a single tag via the set value PB. Depending on the which value is set from the button, another expression tag that will be high. As you can see above i have hour selected, this writes the value 2 to TCA_FASH_METER_VIEW. From there i have an expression on TCA_FASH_METER_V
64f7958609d71
716
mikeb posted Jun 20 '23 at 5:31 pm
I am looking for an example VT-SCADA application. Is there one available for download?
The WeatherApp one I have is apparently quite old and will no longer function in the current release of VT-SCADA.
Any example applications would be appreciated, they do not have to pertain to weather information.
recent by mikeb  ·  Aug 31 '23 at 5:56 pm
143
Scratch posted Aug 28 '23 at 7:32 pm
New to VTScada, installed VTScada lite. Just starting out and having trouble making a connection to an SLC 5/05. I am proficient in Proficy ifix and Intouch. I may take the jump into VTSCADA if I can at least make my first connection. I have tried Port 2222 and 44818 and am using PCCC over CIP, Port path [1,0]. What am I missing here?
133
flagshang posted Aug 30 '23 at 6:00 am
Hi, I want to use the DropTree, would you like to give a sample? Thanks.
https://www.vtscada.com/help/Content/Pro_Functions/DropTree.htm?Highlight=DropTree
193
Hello.
I have an alarm tag that should only cause notifications between 8am-8pm. In other words, be priority 1 during the day, and 3 at night. If the alarm occurs at night, it should notify at 8am.
I duplicated the alarm tag, so that there is a "daytime" (1) alarm and a "nighttime" (3) alarm.
I'm using a trigger tag to disable one or the other based on the trigger.
I have to uncheck
64e8bd2cbf1d9
recent by cardsfan  ·  Aug 25 '23 at 4:46 pm
150
TomE posted Aug 25 '23 at 3:58 pm
Hi Folks,
Two parts I could do with some help:
I commonly use VTScada to generate PDF charts etc. which it works great at. However occasionally when running a "standard report" it hangs up and the only way to resolve this is to disable the offending report tag and then enable again. I have not found a way to do this without going through the tag browser as the option to change this via th
623
mpetruskavich posted Aug 21 '23 at 9:02 pm
Hey everyone,
This seems like a simple problem, but I’m kind of beating my head against a wall here. I’m modifying an existing application on v11.3, which I believe doesn’t have the Allen Bradley CIP driver, so I’m stuck using the older CIP/ENIP driver. I have a direct Ethernet connection from the workstation to a new 5380 CompactLogix PLC, using port A2 (port A1 is be
294
jroc11 posted Aug 9 '23 at 4:52 pm
Currently trying to create a calculation popup for CO2 Usage. I want the popup to show the current CO2 calc tag value along with a numeric entry where a variable tag within the calculation can be changed. It's currently greyed out, so it won't let me enter a value which I assume is because i have it linked to the variable tag that i need to edit. I have tried changing the tag type many times and
64d3b5589cbd5
346
Is there a way to make a Alarm Acknowledge button that will Ack all the alarms in VTScada and send the Ack command to the PLC?
Currently we have layered the PLC Ack command button (momentary button) behind the build-in Acknowlegde All button, and we need to press it twice to Ack alarms in VTScada and in the PLC. Looking for a way to combine it in one button.
recent by JRouse  ·  Aug 13 '23 at 10:45 pm
95
hienho posted Jul 26 '23 at 3:51 pm
I have a new page, how can i query directly value of tag in that page.
101
H2OTom posted Jul 24 '23 at 4:57 pm
Hello, I'm querying values data from VTScada's SQL View tag. I've set up my SQL View tag to include 2 analog tags that store the previous day's total flow for their respective meters. This data updates at midnight each day. The data stored in the tags is always 1 day off.
I'd like for the SQL query to return the values as stored at 08:00:00 each day of the previous calendar month. Also I need
81
hienho posted Jul 24 '23 at 3:29 am
i want to create a new page have a textbox and read data from history then put data to textbox. Dose anyone know ?
83
hienho posted Jul 19 '23 at 10:56 am
how to view source code this page. i want to develop this page.
64b7b320598e0
