Hello everyone,
I'm working with VTScada to read multiple variables from a PLC via Modbus RTU. When reading digital inputs, coils, or bits (using Modbus function 01H), the PLC requires that they be read in multiples of 16 bits.
In VTScada, I use "I/O and Calculations" tags to read these variables, but I haven't found any option that allows me to read multiple bits at once.
I would rea
KC_2965
posted Feb 18 '25 at 3:17 pm
Is there any way to view or export Alarm response time metrics?
For example, I'd like to send a customer something like;
Average Alarm Response Time: 5 minutes
Maximum Alarm Response Time: 30 minutes
Does VTSCADA support this, or has anyone ever ran this kind of reporting?
Thanks,
KC
Is it possible to use IEC104 protocal by interfacing any RTU or relay like RER615 or REF615 on VTscadalight
Thank you
Is there any way to read and write to VT scada tag from other application.
Marco
posted Jan 14 '25 at 8:52 pm
Does anyone know how to connect to Motorola ACE 3600?
The most common instructions are all about Modbus TCP which is not supported by ACE 3600, and I have no idea to make it via Motorola ACE Driver. Does anyone have experiences on that?
I wanted to refresh myself on VTScada, so got the light version installed on a desktop PC that has no connection to the internet. The only connection is to the SCADA server utilizing a static IP address. When I went to assign the Port (TCP/IP) with the address as 127.0.0.1 (loopback) and the port as 501 then created a Modbus Compatible Device Driver set to Address 1 pointed at the TCP/IP port. I
I am looking for advice for a project I have going on. I want to get some data from an InsiteIG product on VTScada. The InsiteIG PT2 to be precise. It offers a RS485 Modbus connection. The existing instrument our wastewater plant was using would of been a YSI product. The communication pathway is as followed; at the instrument it was an ethernet connection then to a media converter that converted
How to write multiple functions into one *.src file
In VTScade it is possible to define your own functions.
Edit AppRoot.SCR where the file with functions is defined.
Then in the file for example NewFunctionName.SRC you write a function.
This works correctly for me if there is only one function in the file, but when you add a second one it says that you are using the used variable.
We have a system running an OEM layer and an application. There have been many tag types added to the Application rather than the OEM. To enable master/subordinate hierarchy for a new site, we want to migrate these tag types to the OEM layer. How can we achieve this with minimal disruption to the existing application? I see there is this help topic https://www.vtscada.com/copy-custom-tag-types-ap
We have 3D files developed by AutoCAD and CATIA (. How to import them to VTScada? I need 3D view in my VTScada project.
Could you please advise step by step?
I see VTScada can add 3D graphics created with 3rd party software (Must be flat jpg, png, bmp) from VTScada website. I am worried I cannot rotate and view from many angles in VTScada if VTScada only supports these file formats.
KC_2965
posted Jan 22 '25 at 2:58 pm
Is there a way to set up a daily report that runs back the last 24hrs of an alarm database history into an excel file?
Also, is it possible to save a "bad actors" report to an excel or CSV?
Thanks,
KC
HaiDoan
posted Jul 28 '17 at 6:06 pm
I have an ipad with the newest iOS firmware 10.3.3, all apps are up to date, yet when I log in the VTScada, after filling out username and password, it gives a white blank page.
Have tried different browsers: Safari, Chrome, Firefox but still not have luck.
I also have another ipad and this one is working fine. So network issues are not this case.
Would you please help me out? Thank
Smills
posted Jan 13 '25 at 10:01 pm
Good afternoon,
I am currently trying to set up SNMP between a Lantronix switch and VTScada. I downloaded the MIB file direct from the Lantronix website, but whenever I try to import the file into VTScada I get the error shown in the attached image below. I was able to successfully load the MIB into iReasoning without any problems and also had Lantronix Support double check the MIB file for
daveinf
posted Jan 20 '25 at 3:28 pm
Hello, Is there a way to silently install VTS 10.2.22 using the 'VTSSetup-Full.exe'. None of the standard command line switches seem to work.
Thanks for any help!
jimt
posted Jan 13 '25 at 11:19 pm
In the Historical Data Viewer (HDV), I'm getting 3 values for a specific timestamp. What is the issue and how do I get only a single value?
TomE
posted Dec 17 '24 at 3:15 pm
Hi folks, can someone educate me on the tank cutaways... there are loads of cutaways in the standard library, is there a way to combine these with a tank image to make a transparent cutaway for use with an analog bar, or are we limited to the tanks that have a transparent bar?
JRouse
posted Oct 29 '24 at 10:19 pm
I am getting SendMail Error[7]: Invaild parameters when VT is trying to alarm out. I have tested through PowerShell and I can get a test email to work. Would this be an Email Server issue or perhaps how I have the alarm notification setup in VT?
RayJS
posted Jan 6 '25 at 12:40 pm
Hi, Looking for advice on how to setup and import tags from a AB micro820. From the documentation about Miro820 tags there is reference to a address select tool. Where is this tool?
If i use the import tags function this results in driver not ready.
Not sure if i have the setup correct.
IP address 10.7.113.53
TCP/IP port 44818
PLC mode Micro820/850 Symbolic addressing
Port p
I am having trouble trying to see the full properties of a Draw HDV object. Currently has 4 trends displayed, trying to just add a 5th. See the screen shots. I tried locating the Group name but can't find it anywhere. Tried searching in tag browser too. Any insight on where to find the location to break this graphic down for editing would be very helpful and appreciated.
Thanks!
Ben
Atomeg
posted Dec 17 '24 at 7:54 am
Hi!
I have a problem with create a pulse bool tag. I need that after push button bool tag goes to 1, delay 0.1~0.5s and after goes to 0.
I'm use multiwrite tag and its not working.
I dont know how set a delay for change tag.
