111
cihat posted Mar 7 '24 at 1:33 pm
Hi, I have been wanting to update the data in a table in SQLserver for a long time. I wrote a script by going through the example in the help files, but I could not execute the script in any way, can you share a sample application about it?
196
Kevin Way posted Feb 28 '24 at 2:16 pm
Is there a way to move the Data Age from a polling driver that is a child to the parent Context Tag/Custom Tag type? i looked through the source debugger for a variable and could not find one. i am assuming this may not be possible with the default context site details widget that is displayed. And yes i know if the polling driver is the parent it displays automatically.
recent by Kevin Way  ·  Mar 2 '24 at 9:02 pm
255
TLDR: I want to create an additional historian. And want all the new tags under a parent context tag to point to the new historian.
I have added a setting in the past to change the server list for all child tags, using "DriverServerListName" setting in a parent tag. Does such a setting exist for historians as well?
My problem is that all of my tag types have been defined and have their ch
recent by Michael  ·  Feb 26 '24 at 9:33 pm
101
Hi Everyone, I am having issues communicating with VTS software using compactlogix L32E from Allen-Bradley..
It communicantes for 10 s ( shows green on the small square) then loss communication( shows Grey on the small square which represents communication status).
I am looking forward to your help please.
Amp
122
EFI posted Feb 26 '24 at 3:14 pm
I am reinstalling VTScada 10.2 for a customer who had a computer crash. I added the old project from a changeset file. I get the following error when trying to run the project:
Is there an easy fix for this?
Thanks
65dcaa675bee6
220
cihat posted Jan 30 '24 at 11:08 am
Dear vtscada authority, I have been wanting to pull data directly from the scada database by establishing an odbc connection for a long time, but I could not establish the connection.
I have two questions:
first one: the ODBC license in the manuals asks if it is active, I do not see this part active or deactive, or even not at all, has this been removed with the new license?
Second: d
223
I have a VT Scada realm configured with 9 applications. When I connect to this realm using the ODBC DSN, I only see the tags configured in the first application of the realm.
Do I need to create a new realm for each application? Can multiple VT Scada realms run on the same machine at the same time without issue?
What would be the best way to approach this kind of configuration? My goal
246
Im trying to use VTScada to poll a Single array from an MQTT Broker. Once i get the tag into VTScada, I want to have the ability to break it apart into its individual tags and im wondering if this is possible or if anyone has done something similar yet??
The length of my array will be around 30 Dint Values. and i want to be able to view each value individually in VTscada after polling the sin
727
I want to make a new page where Sign in Button/Widget placed in the center of the page, apart from at the right top tab given in the VT SCADA as attached image.
It will be also best solution for me if I can move that "Sign in" button to anywhere respectively X/Y coordinates with Height and Width in the new page.
Or else, is there any property or widget or script, through wh
623bfd85a6386
160
How do I create text buttons (inputs) for login access? For example, in VTScada, I created my user with the necessary permissions. In the supervisory, I want to add two input buttons and a confirmation button. These input buttons would be Username and Password. The user will enter their username and then their password. If it is correct, go to the plant Synopsis page. How do I do that? I'm
168
prafull posted Feb 21 '23 at 4:10 pm
I am trying to test the REST Queries .
I have set the application property "RESTAllowedOrigins" to null as given in your example HTML page.
I get TypeError failed to Fetch at the bottom of the page (in Red colour)
Anyone has experience with this REST API Queries?
Any more tips, examples etc?
It's quite frustrating when it doesn't work and we don't get the results as pe
recent by mahin101  ·  Jan 31 '24 at 9:49 am
397
Anbarasu.A posted Jan 18 '24 at 11:17 am
Hi All,
I want to write three status from two different tag values.
"1" Means "Open"
"2" Means "Close"
"3" Means "Travel"
How to write the tag expression referencing another two tag value in VT SCADA.
if [Sludge Dewatering\ZIO_6333A]==1 then "1"
else if [Sludge Dewatering\ZIC_6333A]==1 then "2"
ELSE "3"
164
What I am doing:
Cast(
Concat(
SubStr( [Prod_End], 0, 4), {2024}
SubStr( [Prod_End], 5, 1), {1}
SubStr( [Prod_End], 7, 2), {20}
),2)
This will output 2024120 to a analog calc tag, that i will use in reporting. (I need analog type because other tags are also analog; but thats not the point)
Problem:
You can see the picture that the formatting is not foolproof. This calculation will
65ac93e4181c2
491
I'm currently working through developing some new windows for a client. I'm new to VT Scada and have spent the bulk of my career in Ignition. I was given a changeset file to reference what they currently have or at least within the last 6 months. I started a new application to develop just the new pages and tags that I will import into the client's system.
Traditionally I have always develop
286
TLDR: What is the proper way to ‘wait’ for HTTPSend function to finish its entire api call? The function's url parameter changes from a droplist widget.
I have been testing different ways to run the httpsend function. In the script block of ‘main’ module, in a called module, and as a launched module.
Goal is to change the api link according to user prefer
657fe56f1ada9
recent by Kevin Way  ·  Jan 12 '24 at 3:29 am
134
hilldc posted Jan 11 '24 at 8:52 pm
Currently have two port tags setup for a lift station ... one for cell ... and one for radio. I would like to be able to switch between the two with a selector switch on a page. Possible or not? Better way? Thanks
recent by Kevin Way  ·  Jan 12 '24 at 3:00 am
187
I need to come up with valid expression for two lines of text with a carriage return & line feed separating them. I've done this before but I can't remember where or how. This shouldn't be impossible to find in the help. I know it's in there somewhere but nothing I search for turns up anything useful.
By the way, I am aware of VTScada's multi line text widget. That widget doesn't let
565
Hello, I'm trying to figure out the process for retaining historical trend data during a hardware upgrade, where I am also upgrading the VTS version.
I've found information stating to copy the directory over from the old PC to the new PC, but it seems like I may need to install the same version of VTS on the new machine, then upgrade to the newer version, and I would like to be able to do so
240
I am trying to create a TAG context for a group of Modbus tags.
my data type is IEEE Double Precision Floating Point (8 bytes), and I need to write an expression for the TAG address so that the address will change by the meter number;
Meter #1:
TAG1 address: 31001/Double
TAG2 address: 31005/Double
TAG3 address: 31009/Double
Meter #2:
TAG1 address: 31021
1 ... 78910111213 ... 38
