579
2.03k
30
104
Is there any example of how to set up SNMP Agent Tag Change notification traps? It's mentioned in the help page (https://www.trihedral.com/help/Content/p_AdvancedTasks/pro_SNMPAgent_NotifyTraps.htm) that there is a way to add a simple child tag to do it but there's really no example.
Thanks
230
Bk_reis posted Feb 26 '19 at 1:19 am
i Have a small application for 20-25 tags but I need to set it up so end user can login or access from anywhere. Ideally from a phone or mobile device, Does VTScada lite support that ? If not, what licenses need to be bought.
485
I created a digital control tag that is interfacing with an Allen Bradley Micrologix 1100 PLC with the DF1 driver. When I select the newly created button I receive an "Error Code 256" for this button. What does that error code mean? I have several other buttons on the same screen controlling bits in the same plc and without any issues.
191
Jeff MacKinnon posted Jan 29 '19 at 9:04 pm
I'm interested in talking directly to a Brultech Greeneye energy monitor - https://www.brultech.com/greeneye/
EDIT the attach doesn't seem to work, so here is a direct URL - https://www.brultech.com/software/files/downloadSoft/GEM-PKT_Packet_Format_2_1.pdf for the communication format.
What I'm looking to do is create a datahost application - https://www.brultech.com/data-host/ for the gr
187
Mel Nevergold posted Jan 27 '19 at 7:15 pm
When using Parameter expression to Set High Scale value under the scaling tab of the Analog Status tags it slightly alters the value from the PLC's Tag value. The actual value is 16.4 and is just a stored REAL value not a calculated one.
Also I have to perform a mathematically pointless calculation to get the widgets to use "Tag scaling values"
5c4e0290efdc3
447
Zack posted Jan 11 '19 at 3:06 pm
One of our clients that we recently converted from WW (yay!) is going to upgrade servers soon. Wondering what the method is to transfer existing license from one PC/Server to another. The license was just purchased and is still under support. Thanks!
recent by Zack  ·  Jan 11 '19 at 11:11 pm
229
We have been unable to configure our ModbusTCP driver to 0 address offset. Can you please advise?
We did the following:
1) Make a Context Tag (which will be the parent of the TCP driver)
2) Go to Settings, and add a property: "ModiconTypedAddr1Offset". We set the value to 0.
We have also been unable to write to coils. Could you provide an example of how to write specific bit
608
9
nadeem posted Feb 6 '18 at 8:20 am
Hello every one
I am new to VTScada
Successfully used json/xml driver to read the data from external Device
But i am stuck in how to send data ?
For example i want to send http command when button is pressed !
Any ideas ?
recent by ronniekjr  ·  Dec 6 '18 at 2:42 pm
578
The VTScada on my laptop will not run as an application.
Every time I try to launch it, I get
Error "VTScada is currently running as a service"
"Starting VTScada as an application requires stopping the service, which could disrupt other users or the operation of this installation.
It is recommended that configuration be performed on a machine that doesn't host a VTScada service.
350
I am having a problem reading tags from my OPC Server using VTScada Light. The server is located on an external PC and the connection to the client PC is made through DCOM. I know the DCOM configuration is correct because I can use Matrikon OPC Explorer on the client PC to read all the servers and tags on the external PC. I just can't replicate this within VTScada. This first screensho
5be45a8b4eb55
recent by khillbyr  ·  Nov 24 '18 at 8:22 pm
335
RodN posted Nov 20 '18 at 8:22 pm
Is CSV Import to Historian supported on VTScadaLight?
I am trying to import historic data from CSV files into some tag history. I followed all the instructions on the process, but when I restart the application, it does not load the CSV files after loading and starting the tags.
I have the CSVHistory directory in my application's Data directory, I added the TagMapping.CSV file and the on
