173
Harley107 posted Jul 14 '22 at 1:33 pm
We currently run ge with primary, secondary, and a historian server.
What would be good specs to have server wise running the dual premium server setup 10-25k tags and 15 thin clients. Thanks for the input. Any brand you prefer over another?
110
mike_yung posted Jul 20 '22 at 4:50 pm
This non-working page (https://www.vtscada.com/forums/ ) comes up for me when I search Google for this forum.
Since that page doesn't work is it possible to have it redirect us to https://forum.trihedral.com/ ?
120
tmills10 posted Jun 30 '22 at 1:13 am
Hey everyone, I have a weird issue where if you click on a value (bringing up the trend popup) it brings up every notebook under the parent. I think it happened after I created a trend group but I'm not 100% sure. I have since deleted the group but still, all the notebooks show up.
Has anyone seen this before?
Thanks!!
62bcea47d51be
recent by tmills10  ·  Jul 6 '22 at 4:40 am
158
Tames posted Jun 24 '22 at 6:57 pm
I am trying to open a page in Notepad++ and make edits to the code to change the page when displayed. I have been having a few issues with this.
1) When I edit the .src file and save the code and then open the page in VTScada it does not change. I will close the Idea Studio, close the file folder, or anything else that might have it open that could keep it from updating.
2) T
recent by Tames  ·  Jun 24 '22 at 9:44 pm
340
Stefan_Neamtu posted Jun 21 '22 at 9:47 am
Hello, is there a way to create inside a page a drop-down menu containing links to specific pages ?
For example I would have a button named "Field Devices" and when i click on it - to show a drop-down list - Device 1 page , Device 2 page ... etc
145
When configuring an application and choosing "from a workstation" (via advanced), if I enter a loopback address (eg. 127.0.0.2), or a hostname (via hosts file) that also points to a loopback address, it seems vtscada does not make any attempt to connect to RPC to this address. The use case here is a local proxy server connecting the TCP connection (via port 5780) to a remote VTScada server. Is th
122
Tames posted Jun 17 '22 at 10:11 pm
I am trying to get a Text to load a value of a main TAG. for example a AlarmHi attribute.
I have made some progress but I am having issues with the last little bit to get the final value.
The page has 2 parameters
Tag0(Tag)
TagAttribute(Text)
The one way I can get the expression to work on the text is:
Format(7,1, Tag0\AlarmHi)
What I want to happen is in t
recent by Tames  ·  Jun 20 '22 at 4:24 pm
152
I downloaded VTScada to try out with a Delta PLC, Delta is what we primarily use. According to a PDF on Delta's website there should be the ability to add a Delta Driver in the Tag Browser. The Delta driver isn't listed as one I can add. Here are the instructions I found on Delta's website. Anyone figured this out?
https://filecenter.deltaww.com/Products/download/06/060711/Manual/DELTA_IA_OMS_
136
ftuquabo posted Jun 14 '22 at 7:40 pm
Started creating tags that will be connecting to a Siemens PLC and I am getting an error about Tag Address I'm using. Can someone tell me what;s wrong with this PLC tag's address format?
Could there be an issue in the Siemen's tag driver settings?
62a8d5ed2db1f
616
VTScada stored all history data in its default Historian.
I have used that default historian only in my application and I have logged some values with the default Historian.
How Can I read this store's historian tag values in MS SQL Server?
I have installed the VTScada ODBC Driver and also add SQL Server Driver in User DSN on ODBC Administrator.
This SQL Server Driver I have conf
recent by Ketul  ·  Jun 10 '22 at 4:49 am
377
Does VTScada's built in e-mail client meet the security requirements Google describe
here ---> https://support.google.com/accounts/answer/6010255#more-secure-apps-how
and here ---> https://support.google.com/accounts/answer/3466521
Many of our customers are using gmail to send alarm notifications. We've upgraded some of them to VTScada and are not sure what will happen when google
recent by mike_yung  ·  Jun 8 '22 at 8:49 pm
205
abec34 posted May 26 '22 at 11:46 pm
I am receiving a value of 273 from the BACnet driver but within Wireshark capture I am getting no errors and can see the correct Value being returned.
Any idea why VTScada is giving out an error code of 273? The tag I created has no value which I am assuming since the driver is getting a value of 273 and not 0?
Here is what VTScada is showing:
but here is the proper value comin
6290026f65914
recent by abec34  ·  Jun 6 '22 at 11:26 pm
126
Hi all,
This whole OT/ICS world is pretty new to me but I am trying to pick it up and work my way through it, but just looking for a bit of help with something.
I am trying to set up a virtual lab to demo how easy it can be for a hacker to change values and mess with OT equipment if the network is not correctly secure. Originally this was just with getting remote access to a private comp
164
Tames posted May 25 '22 at 9:38 pm
I have noticed that if I am using a text box that I am unable to type ".00" to the end of a number, really any length of that .0, .000, etc. If I type it in the program automatically removes it.
It is a small thing but it creates uniform numbers when I have to list of a few of them and the rest have single or double decimal places.
If there is a way to turn that function off?
recent by Tames  ·  May 26 '22 at 4:22 pm
179
Ketul posted May 25 '22 at 5:29 am
I have secured my thin client link with the SSL X.509 certificate.
(I have made a new CSR request with my host+DNS name. I have validated the request from my CA & they send me the key and certificate. That I have to do Process Reply in SCADA and it successfully proceeded. I have added the SSLCertName property in my APPRoot file and restarted the application and ticked the SSL (443 port) op
628db0ac9d963
131
jjanowiak posted May 20 '22 at 11:09 pm
I want to create a custom Site Map Icon.
I would like to click the site icon on a map and have it take me to the related display for that site.
Here is what I have.
I have a Context tag. On the Display tab I entered the Lat and Longitude.
I entered the page name in "Custom Details Page".
When I click the Icon on the Site Map display, it opens my display as a pop up. I want it to
506
Ketul posted May 23 '22 at 12:33 pm
How can I import one machine history data to another machine. I want to copy all historical data of trends & reports onto another machine.
I have copied the Data folder of my application to my another application and replace the folder but I'm not getting Historial data inti it.
Is there any extra steps needs to perform here?
