213
8
I am working on my first application for my city's water treatment plant and distribution system. I just noticed in the developers guide it states that digital control tags do not retain their values during app restarts. Most of our pumps are started and stopped manually and I do not want anything SCADA related to shut them down. Should I use Analog control tags set to 0 and 1 for this situat
recent by Michael  ·  Mar 17 '20 at 6:56 pm
231
BDemaree posted Mar 3 '20 at 4:24 pm
I need to create an XY plot of the data from 2 tags but am having difficulty doing so. I have looked at the PlotXY function but am unsure of where to use it and how to get the arrays of data needed for the function.
recent by Victor  ·  Mar 5 '20 at 3:22 pm
217
pushpika1 posted Feb 19 '20 at 9:18 pm
hello sir,
I`m pushpika from Saudi Arabia.I have designed a scada system for my company and it is approved to implement. i am using VTscada Light version to implement this project.this project includes water flowing system with chiller lines and etc.. i am planning to use Modbus compatible device to my project instead of PLC.i have already choosen a device.but i need to make sure it will be c
recent by pushpika1  ·  Feb 25 '20 at 8:24 pm
176
mjmadsen posted Feb 24 '20 at 6:58 pm
I would like to use VTScadaLight to send process data to an OPC UA server so that other OPC UA compliant programs can have access to that data.
Does VTSLight support this functionality or do I require a fully licensed version of VTS?
If VTSLight does support this functionality is there documentation that describes how to configure it appropriately.
OPC
106
pushpika1 posted Feb 20 '20 at 8:04 pm
Hi..
i`m using vtscada light version and i have Omron NJ series plc.when i trying to setting up plc with vtscada application,it shows only two series there.C/CV series and CS/CJ series.so NJ series not supporting with vtsada?if support, how to add drivers?which one i need to select while adding drivers ?omron fins driver or omron host link plc?please let me know.thank you.
317
I attached an excerpt from the help files, but I would like to discuss it for a second.
file:///C:/VTScada/VTSHelp/Content/D_Tools/Dev_Backups.htm
If there is a single application on site, and we need a backup solution that is automatic AND shutting down and restarting the application isn't possible, is using windows file history an acceptable method for continuous backup?
Has ther
5e4c9236a66ab
190
Carmelo posted Feb 4 '20 at 5:21 pm
It was not difficult to communicate a Koyo PLC with VTScada by means of Modbus TCP, being both, PLC and VTScada in the same LAN.
However, I have not been able to communicate them when the PLC is connected to a router outside the LAN of VTScada.
I typed a public IP address and the PLC port number when configured the TCP/IP port in the VTScada.
The resulting value of TCP/IP Port is -10,06
157
packinpennies posted Feb 17 '20 at 6:17 pm
I am having an issue connecting to a Koyo DL330 PLC via serial. I have it setup with the correct station addresses and COM port parameters, and it appears to be reading my register R16 correctly. However, writing to the tag fails. Sniffing the serial packets, it appears that the driver is trying to pull data from 2 8-bit registers when I only want to pull from one and I believe this is w
232
dougs posted Feb 5 '20 at 5:10 pm
Some people have been having an issue connecting to the Microsoft Store and downloading the Excel plugin. A lot of these we have found are because of the Excel build. Note that Excel can be up to date with security patches but still be behind on builds.
The add-in currently requires what is known as the ExcelApi 1.4 requirement set which is available in build 7870.2024 or later, so although y
5e3af83f95e85
216
pieter posted Jan 31 '20 at 3:30 pm
For a school I work on three small PLC controlled processes supervised by separate VTScada applications to manage
some food processing equipment (evaporator, powder dryer machine, autoclave) that the students have to learn to work with.
Is there a report tool for VTScada that enables me to document the details of the tags of these applications in an organized way for the project document
recent by pieter  ·  Feb 14 '20 at 12:16 pm
116
jfrye posted Feb 10 '20 at 8:07 pm
We are trying to create a report for documenting the duration a sewage lift station is overflowing on a day to day basis.
We have a calculation tag setting the overflow setpoint, and an alarm tag running the trigger of "wet well level > setpoint". Followed by a logger tag monitoring the state of the alarm tag, logging at every 60 sec.
When we run daily total reports on the logger
recent by jfrye  ·  Feb 12 '20 at 12:35 pm
183
DanW posted Feb 7 '20 at 5:03 pm
So... in the past Calculation tags have been used to create Color tags.
With VT12 this can be done using the Universal IO Tag: String Calculation but it seems that most objects object to picking String calculation tags { see what I did there }. When picking a color for a box and you select tag and go to choose a tag, it looks for numeric tags. Interestingly, you can select the tag in the lef
recent by DanW  ·  Feb 11 '20 at 8:55 pm
114
DanW posted Jan 29 '20 at 3:04 pm
The VTScada help file indicates that the RadioButtons function should be called using the Dot notation:
\System.RadioButtons(.....);
When I attempted this implementation the radio buttons did not show up in my display. After verifying my variables I tried using the "\" notation:
\System\RadioButtons(......);
This worked.
(Full Disclosure: I'm using the VT11 era "CompletedTutorial" ap
194
jjauregui posted Feb 5 '20 at 12:20 am
I am looking to display the following VIC Client information in a project:
Server Name client is connected to
Client Name
Logged in Windows username that the client is running on
For item 1 (Server Name) I am using the following expression which is working fine: \DisplayManager\RootSession\Name
How would I reference items 2 & 3 above?
recent by Michael  ·  Feb 10 '20 at 3:27 pm
122
drummin89 posted Feb 6 '20 at 2:40 pm
Is there a way to resize the horizontal buttons widget for a selector switch tag? It seems like it would be standard practice to have some user set-able parameters in the properties dialog for setting the width and height of the buttons, but there is not and the buttons are just too small.
recent by Michael  ·  Feb 8 '20 at 6:04 am
396
BFleck posted Feb 5 '20 at 7:04 pm
Getting error code 33,028 when trying to connect to Siemens S7 Driver. I'm using VTSCADA Light Version 12.0.04.
Any Help is Appreciated
Found Solution
Open the PLC project in the S7 TIA Portal software.
Go to Project View
In the Project Tree window, select the device that is causing the error.
Hit Alt-Enter to bring up the Properties dialog.
On the General tab,
200
Hi, I would like to put a numeric entry box somewhere in my application so that the alarm parameters (like low alarm setpoint) can be changed without the user having to go into the tag properties. Is it possible to reference these parameters outside the properties box? for example like how you can reference a tags value by using \Value
If that is not possible then is it possible to create a t
116
dbabler posted Jan 23 '20 at 1:24 pm
Has anyone experienced issues being online with an Allen Bradley PLC, causing VTScada to slow down or even lose communication at all? Doesn’t really cause any major issues (yet) but I’m curious if anyone else has seen this, thank you
recent by Michael  ·  Jan 23 '20 at 3:02 pm
221
Ketul posted Jan 18 '20 at 1:15 pm
I want to write an expression on "digital status" tag. According to changing in value of digital status tag, different text should be shown.
As like, If digital status tag value is 0 then it should shows 'disabled', If its value is 1 then it shows 'running', if tag value is 2 then it shows 'blocked', if the value is 3 then it shows 'unknown'.
I want to write an expresion in tags. How can i
182
jfrye posted Jan 22 '20 at 2:18 pm
Looking for the best way to configure resolutions between 10 pack applications and various client size displays. We have 15" 1024x768 HMIs at our panels, these using the 10 packs so we can filter by panel number. Then we have 27" and 32" monitors in our operator room running the main application on the VIC, and then programmer staff use 24" monitors.
Here is a look at how we have one of the
5e285923d3c34
157
Ketul posted Jan 18 '20 at 2:00 pm
I have used VTScada in my pumping application where my pumps are start&stop according to level in sump.
When my level goes above to start level it will start my pumps & when level reaches below to stop level it will stop tye pumps.
I have used level tag(analog control), pump running status tag (digital status), start & stop level tag(analog control) etc.
I want to animate my
171
10
DanW posted Jan 20 '20 at 7:59 pm
The High Performance HMI Handbook (Scada Bible) suggests that Faceplates should have a reserved spot on displays that change according to the item selected on the display.
Everything on the screen is selectable, and when selected the standard faceplate for the element appears in a reserved “faceplate zone” rather than floating around the screen obscuring the graphic.
Element m
recent by DanW  ·  Jan 21 '20 at 1:11 pm
