76
Please provide an example of how *this is done.
May be set in a parent context tag if you have Modbus devices with differing address offsets.
I have no idea how to put a context tag into an application's configuration.
... * referring to latest help
251
This help page describes thin client licensing as follows.
If you have a multi-server application and want to allow connections to more than just one server, each must be licensed to allow client connections.
It is common for one of your server keys to allow many thin client connections and the others to have few or none.
172
Tames posted Feb 21 '23 at 9:40 pm
I built a Lufkin SAMS controller inside of my VTScada and it automatically built all the TAG's as either Analog Status or Digital Status TAG's (Legacy TAG's) I am trying to set the lowlow / low / high / highhigh limits for the Analog Status points but I found that these types only allow for a Low/High alarm, but in the support document the picture used for this TAG is the Calculations I/O Analog
63f53a2ec823a
recent by Tames  ·  Feb 22 '23 at 3:32 pm
170
Hey guys,
We have a decently large application (80k tags) with lots of Flow Computers. We have Low Flow setpoints and Debounce timers settable by operations and just go the Alarm tab on each Analog Status (FC still uses old style tags).
One issue we've noticed is if you change the parent tag type, or have a hard shutdown due to server issues, all these values get wiped out and get set to
recent by tmills10  ·  Feb 21 '23 at 9:23 pm
91
I would like to use the selector switch tag type as it has built in feedback alarms and the switch widgets. However, the components I am using will pulse the command to its state. Another reading will verify that the command worked and that the component is in the commanded state. I don't see an option to pulse the output of the selector switch. Will I have to use the digital IO tag and a cou
98
I tried to setup Thin Client access to the VAM according to the online help but got stuck at this step.
' 7. Create a user account and grant it the VTScada Thin Client privilege.
I couldn't find a "Thin Client privilege" to add to my account but adding "Internet Client Access" seems to work.
If I've done something wrong please let me know what I need to do to access the VTScada Thi
236
Parent Child References are the easiest to map. However, I am exploring the possibility that the hierarchy for an application might require references to properties in an adjacent tag in the hierarchy. I haven't run into issues when concatenating descriptions in this way. However, in other values that require a specific data type (Scan Intervals, Drivers, AIO Scale Min's and Max's), I have exp
177
Jason posted Feb 13 '23 at 7:59 pm
Would anyone happen to know a way I could have a button do 2 different things on a single press? Like set values to 2 different tags or set a value and change screens?
recent by Jason  ·  Feb 14 '23 at 6:51 pm
66
steven posted Feb 9 '23 at 7:14 am
i haw installed VTscada 12.1.12 and trying to add a OPC UA Client driver in my tag Browser. but when i selecting this type, the program closes.
is the VTScada light supporting OPC UA Client Driver?
159
mike_yung posted Feb 3 '23 at 2:25 pm
Has anyone found a way to print a full help topic from VTScada's online help? The only workaround I could find is selecting all the text, then copy pasting. If anyone's got something better I'd be excited to learn from you.
https://www.vtscada.com/help/ is not the only website with this issue.
It seems like it's a common problem with sites which haven't been upgraded to remain compatib
recent by mike_yung  ·  Feb 8 '23 at 4:11 pm
120
I was hoping to take an existing VTScada application which has been running for 6 months and create a duplicate copy of the application & its data to run side-by-side on the same PC.
Can this be done? I thought I'd use the "Get from ChangeSet" option but the Wizard doesn't let me rename. The "Clone from ChangeSet" option does however clones don't contain data. Is there a way to copy th
317
Hi folks, having problems with the reporting tag, and the time duration for this. I would like the duration to match a calculation tag. I am using the tag as a reference in the parameter for the Report Duration as shown in the screenshot below.
However, it does not act as I would expect… and I have had to create multiple report tags to get around it in the short term… however t
636c3a996998e
1.2k
I have been trying to set up a connection between VTScadaLite and a Allen Bradley plc using Ethernet/Ip. From what I can gather I am using the correct driver and tag set up. But the digital [IN] does not register a value coming from the PLC.
The PLC can be pinged and ports have been enabled with all firewalls turned off.
The running PLC program is being monitored using the CCW s
101
Source: Scripting->Custom Tag Types->Create or Assign Tag Widgets->Sample Widget
Copy and paste to sampleWidget.SRC.
Inport in Idea Studio.
Error:
Compilation Error
Trace Item GUID 3eb6e21b-7338-46f6-b65a-88cd290ec584
Timestamp Mon Feb 06, 2023, 22:50:17.569 (Taipei Standard Time)
Application OEM_01
Application GUID de535
134
artistmonkey posted Feb 6 '23 at 8:24 am
I'm just learning to create a sample open page widget script and need help accomplishing what I want. I know there is already exist a button to open page.
How can I show color parameters like embed widget (color selector)? [solved] need to create panel
left click release event, how to attach? [solved] GUI Object Return Codes
Below is my sample script.
63e0b82f657fd
185
Joseph "JD" Rhodes posted Feb 3 '23 at 2:24 pm
I have been having some issues with VTScadaLIGHT regarding some what appear to be inconsistencies. I have followed both VTSCADA academy and the Student Workbook: VTScada Operations & Configuration Course handbook to set up a simulation environment where I can learn as much as possible. I have followed both avenues of instruction only to end up with the same result. I have values of 770 for co
63dd1914023a7
115
ron543 posted Jan 31 '23 at 11:09 pm
I am using VTscadaLight and trying to connect to Cogent DataHub OPC UA Server.
I am able to successfully connect between VTscada and Cogent with OPC UA client tag and TCP port driver.
I have DataSim setup to data to Cogent DataHub.
However when I try to import the tags, I get a large number of errors which are all error code 32783.
This error code is not in the documentation so I am n
350
This question was left on our YouTube tutorial for the VTSCada JSON driver found here...
https://www.youtube.com/watch?v=gegzTIR88EE
Question: "Can you pass functions or vtscada parameters in the URL? I.e I want to use the latitude and longitude which are specified in the parent of the JSON/XML tag?"
Answer: Absolutely. You can put parameter expressions in the URL which reference V
113
mikeb posted Jan 27 '23 at 1:57 pm
In June of 2022, Microsoft released an update which by default harden DCOM connectivity to OPCDA and OPCHDA servers. I am aware that this can be disabled, but that option will no longer function in March of 2023.
Does the latest version of VT SCADA support the new DCOM Hardening for remote OPC DA Connections to the VT SCADA Real Time server?
107
I have created a script to store recipe in a Network Value variable. This variable is declared in Approot.src under NETWORKVALUE. code works fine till application is running but the problem is when I restart the application I can not find stored recipe. Is there anything I am missing which results into this problem ?
130
I am trying to create a text port that allows the user to enter a lift station number and then click to open the detail page for that station. In order to make everything work smoothly I need my lift station number to resolve to a three digit string. Is there a function that will force leading zeroes in an integer to string conversion? The Format function seems to operate in exact reverse of what
113
ryleigh.hargrave posted Jan 12 '23 at 4:21 am
I'm currently building an alarm annunciator for speech to text alarms spread out over multiple areas and where there may be multiple alarms active at the same time. I was wondering if there was an option, or if it can be done through scripting, to replay the list of unacknowledged alarms after a set time out and then repeat the cycle until all the alarms have been acknowledged. This would be for
1.3k
8
I have programmed DNP Binary Output controls on my pages and the manual states that if you send an analog value to the tag of "-5000" it should sent a 5 second "Trip" pulse and if you send a value of "5000" it should send a 5 second "Close" pulse.
When i look at my wireshark logs and in my SEL RTAC i just keep getting 1ms Close pulses no matter what i configure.
My points are configured a
212
Problem 1: I'm trying to execute a file based on a trigger. It is to accomplish something another SCADA software could do. It will run a batch file that combines csv files into 1 csv file. I am using a trigger tag to change an analog value. Then use that analog value to execute a script tag. The new SRC file (SpawnFile.SRC) and variable was declared in the AppRoot.SRC file per the help documentat
recent by Vic  ·  Dec 30 '22 at 5:01 pm
