212
Dear All,
I'm very new to VT SCADA and after all the tutorial I watched, I couldn't find the answer (or maybe I missed it) to a problem I'm facing.
I want to configure a push button to start/stop a piece of equipment, and I was wondering if I could read the state of that equipment and send the opposite value through the button.
I saw that it is possible to write a static value in the "Va
85
I am trying to Generate report and export tag values to my local mysql database.
I have provided ODBC Data Source name same as in the System DSN I have made in odbc data source manager in windows as you can see in this screenshot.
Why am I getting this error despite ‘vtscadaodbc’ being a valid mysql connection ?
Is there a different syntax or any more step t
634da05d5e290
190
bbaer22 posted Oct 11 '22 at 9:01 pm
I would like to use a Text Change 2 state, and when it's in the 0 position or non energized state I want it to show one word in a certain color and in the 1 position I want a different word and color. It doesn't look like it would be tough, but I can't get it to accept a tag. I tried a bunch of different kinds of tags and it's just not accepting any of them. I would like to use a tag for this sin
recent by bbaer22  ·  Oct 14 '22 at 5:48 pm
598
I have been using Vtscada for some time now on a PC windows 10.
I keep getting password login error...
I setup the port to 83 to make sure I am not clashing with anything..
I am trying to use the MS EDGE browser to access the Vtscada app locally...
http://192.168.1.250:83/all/soilsensor/anywhere
When I run the app soilsensor, I enter the username password which I tried many f
169
Hello everyone,
I'm playing with VT-Scada, and I encountered a problem I didn't find any solution.
I searched in the documentation but I found no answers.
I wish to plot measured data from different (but consistent) inputs in a single graph, each one with a different colour.
Is it possible to do so? If yes, can anyone tell me how?
Thanks a lot,
P
145
First I installed 90 day demo version in my laptop. I developed the project in that demo version. I purchased the Developemnt License key.
So, I deactivated the demo version. Now I am trying to activate it again using the licensed key(25 Chaaracter). But it is only giving option to enter 16 digit key.
Suggest how to activate it + I also want to use my existing changeset file developed on
632dbf00af8fb
268
I have some string data internal to my Siemens S7 PLC that I want to display. When I use the string tag type all I get is the number value of the data block.
Is there a way to easily display as ASCII?
Also how to display the whole string, my string data is assigned 6 bytes in my PLC, but the maximum VTSCADA allows is 4 bytes, one double word?
For example my string is located
344
ScottEdlin posted Sep 13 '22 at 9:43 am
Hi All,
New to VTScada and evaluating the light version for our manufacturing plant.
I want to display different text (strings) based upon a tag value from our siemens plc, I am getting different values through but can't work out to conditionally call different texts based upon this value.
So for example if tag Part number == 1, display SK90
if Part number == 2, display SK110.
113
jjanowiak posted Sep 6 '22 at 10:37 pm
I have a SCADA system that is not connected to the Internet, like most every SCADA system I work on. I have copied the Slippy Map Tiles for my area to my SCADA server. However, my map icons do not appear on the Map. No matter how far I zoom in or out.
How do I get my Map Icons to appear if I don't have an Internet connection?
151
Tames posted Jul 20 '22 at 6:47 pm
I have taken over a job and the previous creators used:
SState0Color
SState1Color
SState2Color
SState3Color
to pull in the colors form the style settings without pulling in the alarm color override. I have copied and pasted their code (from a working widget) and pasted it into my own but it does not work.
The code is:
\Root\Value == 0 ? SState0Color : ( \Roo
189
jjanowiak posted Jul 12 '22 at 1:05 am
Can someone tell me where to find the "Web Browser Widget"? The help says it is located in the "Tools\Web Browser Tools" folder but that folder does not exist in my version of VTScada. Is this an add on that needs to be imported or something?
96
mike_yung posted Jul 20 '22 at 4:30 pm
This section of the help (linked to) tries to refer me to Microsoft for details on how to get a signed SLL certificate but the url which used to give that information now tries to upgrade me to Windows 11.
Please reply with the instructions for processing a reply to an SLL signing request & arrange for this to be added to your online help. Thank you.
https://www.vtscada.com/help/Con
272
We're currently sending our customer's VTScada e-mail alarms through a dreamhost mailserver but need to switch that to our customer's Microsoft365 mailserver with OAuth 2.0.
Their ISP has given us all the credentials we need. All that's missing is our redirect URI & certificate.
Is there anyone here who can baby step us through those steps? I've been reading & re-reading the V
355
I want use JSON/XML Driver in VTScada A to read a tag from VTScada B.
The VTScada B has configured the corresponding parts. So I can get tag1 data in browser with URL "http://192.168.1.2:8080/web/REST/SQLQuery?query=select timestamp,'MyTest\Machine1\CommDriver\Tag1:value' from history ORDER BY Timestamp DESC limit 5" from VTScada B.
The data is as below:
{"results":{"fieldNames":["t
6180d8d58e67d
215
ftuquabo posted Aug 29 '22 at 1:50 pm
When purchasing Support Plus Renewal, are new license keys generated and must be updated on the machines the original licenses were activated on? Or do the license keys stay the same?
recent by ftuquabo  ·  Aug 29 '22 at 3:19 pm
265
jjanowiak posted Aug 25 '22 at 6:07 pm
I have some motor data that I want to display on my SCADA screens.
I have tags for various info like Pump HP, Name, Install date, etc.
If I make changes to my app and then import the changeset, all my tag values get reset.
Is there a way to maintain the tag values even through a changeset import?
I'm thinking that importing the information from a text file would work. My problem is
recent by jjanowiak  ·  Aug 26 '22 at 4:28 pm
228
AndrewW posted Aug 18 '22 at 10:13 pm
Good Afternoon,
I was trying to install VTScada lite earlier today, and ran into the following message "The program can't start because api-ms-win-downlevel-kernel32-I2-1-0.dll is missing from your computer, try reinstalling the program to fix this problem".
I made sure the computer was current on its windows updates, and tried to reinstall, and I ran into the same issue. The computer is
228
kurtisjackson posted Aug 10 '22 at 10:26 pm
Hello.
I'd like to ack an alarm tag when an operator selects a reason (in this case, DowntimeCode, for the alarm to be active.
I've been using \AlarmManager\Ack(MyAlarm); as per the documentation to attempt the ack. This is my first crack at using \AlarmManager\ but I hope to use it a lot.
My testing "AckAlm.src" script is as such:
DowntimeCode; {Selected Reason for
74
flagshang posted Aug 8 '22 at 9:53 am
I have a standard modbus PLC。There are some characters in address 40000,40001,40002,40003,40004。Can I only set address 40000 and address length 5 (from 40000 to 40004) into VTScada "String Data type I/O Tag properties"?How can I do that? Thanks.
173
ftuquabo posted Jul 27 '22 at 2:40 pm
With the Alarm Priority Icon Widget, is it possible to assign to different colors to the different alarm priority levels, (Level 1, Level 2, Level 3, Level 4)?
I looked into using a style setting tag, but it seems I'm only able to assign one color for the "alarm state" and can't define alarm colors for each priority level.
Any insight on this would be greatly appreciated.
