159
dgonsior27 posted Mar 6 '19 at 5:49 pm
So...I have two report tags reporting 15 analog inputs on a standard style report, outputing to a CSV file in a folder on a server. Custom preset at 1 second duration, and 1 minute end time. The report tags are triggered daily at 1:55pm, and 4:55am. The reports successfully generate but only with time/date information and analog input tag names...no values. Any ideas on where I might be going
505
Just downloaded the software and thought I had an easy project to start with. Took awhile to grasp the Tag hierarchy but think I have it.
My problem is this: Trying to setup VT to read from a Modbus TCP slave. I have tested the slave communication with a small Modbus TCP app, running on the same PC as the VT app and it works fine.
The ModBus TCP communication parameters are:
Slave I
544
Hi all,
I'm trying to connect to a TCP modbus server running on the same machine as the instance of VTSLite. I've confirmed the server is operating (with a different client), but I can't seem to get my VTS application to write or read any addresses.
I've followed the process here to make my tags, using "localhost" as the IP address and the same port as my server (standard 502) https://ww
5c59f0d18bd61
158
clewis posted Feb 19 '19 at 5:08 pm
Is it possible to show an analog status tag in a gridlist cell? Would it display the alarms and engineering units?
In the titles parameter how would you Display Multi-line text
Do you have any examples?
recent by clewis  ·  Mar 1 '19 at 5:38 pm
105
Is there any example of how to set up SNMP Agent Tag Change notification traps? It's mentioned in the help page (https://www.trihedral.com/help/Content/p_AdvancedTasks/pro_SNMPAgent_NotifyTraps.htm) that there is a way to add a simple child tag to do it but there's really no example.
Thanks
232
Bk_reis posted Feb 26 '19 at 1:19 am
i Have a small application for 20-25 tags but I need to set it up so end user can login or access from anywhere. Ideally from a phone or mobile device, Does VTScada lite support that ? If not, what licenses need to be bought.
162
Mel Nevergold posted Feb 20 '19 at 1:57 pm
I want a widget to drive to the site via long,lat that I can launch from the anywhere client.
I think this might help.
https://developers.google.com/maps/documentation/urls/guide
I've got an idea to try. BRB
gps
485
I created a digital control tag that is interfacing with an Allen Bradley Micrologix 1100 PLC with the DF1 driver. When I select the newly created button I receive an "Error Code 256" for this button. What does that error code mean? I have several other buttons on the same screen controlling bits in the same plc and without any issues.
191
Jeff MacKinnon posted Jan 29 '19 at 9:04 pm
I'm interested in talking directly to a Brultech Greeneye energy monitor - https://www.brultech.com/greeneye/
EDIT the attach doesn't seem to work, so here is a direct URL - https://www.brultech.com/software/files/downloadSoft/GEM-PKT_Packet_Format_2_1.pdf for the communication format.
What I'm looking to do is create a datahost application - https://www.brultech.com/data-host/ for the gr
1.5k
9
RyanCaleb posted Nov 9 '17 at 1:31 pm
Hello everyone,
I'm a beginner with raspberry pi and also to Python language. I'm trying to use the raspberry pi 3 for industrial application and for that I've connected quite a few sensors (temperature, humidity, co2 etc.) I'm successfully able to get reading from the individual sensors and wrote a structured program with few functions related to each sensors to get reading from all the sens
187
Mel Nevergold posted Jan 27 '19 at 7:15 pm
When using Parameter expression to Set High Scale value under the scaling tab of the Analog Status tags it slightly alters the value from the PLC's Tag value. The actual value is 16.4 and is just a stored REAL value not a calculated one.
Also I have to perform a mathematically pointless calculation to get the widgets to use "Tag scaling values"
5c4e0290efdc3
417
I'd like to monitor, decode, and "interact" with a Modbus RTU device. Nothing complicated, I don't think. When I say interact the "linking" of meters/graphs to some of the registers etc would be really a nice to have and that seems to be inherent to your application.
Question:
Is VTscada Light the product I am looking for?
I reviewed the manual and looked at the software after insta
165
hank posted Jan 10 '19 at 7:50 pm
Hi Guys. I'm installing VTScada in place of another SCADA system and need a way to replicate the old watchdog functionality that they were using. Currently, their old SCADA system toggles a bit for each RTU, based on a set interval, and that bit is tied to a point in the RTU that will cause an alarm on site, if the bit stops toggling (loss of comms).
I believe I will need to do this using sc
448
Zack posted Jan 11 '19 at 3:06 pm
One of our clients that we recently converted from WW (yay!) is going to upgrade servers soon. Wondering what the method is to transfer existing license from one PC/Server to another. The license was just purchased and is still under support. Thanks!
recent by Zack  ·  Jan 11 '19 at 11:11 pm
165
Our application style is a container one having three windows:
Top: Toolbar with several subsystems, each having submenu action buttons. Action button change the graphic represented in middle window
Middle: Graphic application area
Botton: Alarms
Is it possible to create a VTScada application with this shape?
See examples in attached images:
5c36d90b6dff6
230
We have been unable to configure our ModbusTCP driver to 0 address offset. Can you please advise?
We did the following:
1) Make a Context Tag (which will be the parent of the TCP driver)
2) Go to Settings, and add a property: "ModiconTypedAddr1Offset". We set the value to 0.
We have also been unable to write to coils. Could you provide an example of how to write specific bit
259
Scenario:
Redundant server configuration (Primary + Backup)
Primary server online and working OK
Backup server ready but in standby mode (no coms/history..)
Several Operator Workstation on local network
The operators normally logged in Primary server
Then, primary server shuts down by any anomaly or forced event.
The question is how the Operator Workstations recover connection with Backup
613
9
nadeem posted Feb 6 '18 at 8:20 am
Hello every one
I am new to VTScada
Successfully used json/xml driver to read the data from external Device
But i am stuck in how to send data ?
For example i want to send http command when button is pressed !
Any ideas ?
recent by ronniekjr  ·  Dec 6 '18 at 2:42 pm
