89
colinpetersen posted Sep 13 '24 at 8:19 pm
Wondering if anyone has built a data table drag and drop widget. Looking to create a drag and drop table that functions like Excel spreadsheet (e.g., filter, sort, search on column headings). Connect cell data to tags for population or manual input. We are currenly building a table however the process is very manual (e.g., need to rescale everytime a column is added etc.).
257
11
I am going behind someone on an unfinished attempt to display alarm counts by area. Below is an alarm query tag calculation path for the influent pump station area:
\AlarmManager\GetAlarmStateStats(Scope(Self, "01_IntakePS")\ActivePriorities["0002"] : Invalid
I am getting no value results. Does anyone have any insight on what may be wrong with this parameter or if there is another metho
recent by benleeper  ·  Aug 30 '24 at 7:25 pm
75
mason.krei posted Aug 29 '24 at 9:40 pm
I'm attempting to create a "tabbed child window" on a page where selecting a different "tab" changes the content of the "child window". There are a lot of built-in examples (e.g. refer to image of Equipment->Station All Outputs below), but I'm unsure how to modify or recreate the widget for my own use.
Please advise, and thank you.
66d0dbccc4e5c
196
Tames posted Aug 13 '24 at 7:03 pm
Just wanted to check in and see if I am doing something incorrectly inside this window.
I just have a bunch of widget selected at once. I wish to delete multiple widgets in this selection. My first instinct was to just right click a widget inside the window and click delete. The surprising part is that the system then unselected all of my widgets that I had selected. I selected the group aga
147
Tames posted Jul 31 '24 at 4:30 pm
I am trying to find a way to change the Font colour of the Droplist widgets Title text. The Style and Font links are for the text in the droplist but there seems to be no option for the title text. It currently defaults to pure black and this is not a great colour for me to use in the HMI I am using this widget on. Is there a work around to be able to change the colour of the TITLE text?
Than
recent by Tames  ·  Aug 27 '24 at 8:09 pm
174
cihat posted Aug 14 '24 at 7:37 pm
Hello, I am preparing a report, for this I want to bind it to a tag using the add parameter expresion to the duration value by selecting the time custom in the report tag, but it is said that I need to enter a value in the range 1-32767.
Can we make the I/O tag suitable for this. Obviously, I am creating the report time with the totalizer. I should somehow automatically assign this totalizer
recent by cihat  ·  Aug 23 '24 at 1:46 pm
122
j.schroeder posted Aug 22 '24 at 4:45 pm
I am looking to test the state change of some I/O tags, analog inputs for breaker status. Is there a way to force a value for the tag so I can see the Text Change and Color Box widgets change text and color?
recent by TomE  ·  Aug 23 '24 at 10:11 am
241
Atomeg posted Aug 12 '24 at 8:22 am
Hi!
Im trying to show popup window on internal tag change from false to true, but it doesnt work.. I write in source code this code (this code in Main [..]):
If [test_bool_tag]==true;
\DisplayManager\ShowPage("test_page");
Maybe I'm doing something wrong or other better ways to do this?
recent by TomE  ·  Aug 12 '24 at 1:51 pm
157
PMcCutcheon@macroeng.com posted Jul 29 '24 at 2:11 pm
Hello:
Very new user here.
I'm looking at a very small test system. Mainly looking to do some trending. Not looking for redundancy, etc.
I create an application on my laptop. What's the path to move that to a "working" computer? Can I export the application from my laptop to a USB stick, then install on the target?
thanks
142
PMcCutcheon@macroeng.com posted Jul 29 '24 at 2:29 pm
What is the "intent" of a plot versus the HDV? Where would I use one and not the other?
Looks like plots are single pen?
I want to create a trend with several variables that always looks the same when it opens ... same scaling, time range. My first thought was a plot, or series of plots (because the HDV is a new concept to me) but maybe there is a better way?
thanks
192
zwoods posted Aug 7 '24 at 7:29 pm
I have 2 apps running on the same VAM. I'd like to merge these apps together keeping all data. What's the best way to do this? I believe a changeset would work but I would like confirmation or ideas on other ways. Not much info on this specific topic in the reference guides.
------Edit----- I see that a changeset will not work in this case based off "create a changeset" section.
recent by Michael  ·  Aug 7 '24 at 7:41 pm
702
Has anyone connected VTScada MQTT client driver to AWS IoT Core MQTT broker successfully? I have a device publishing to a AWS and I can see the data coming in on the topic.
I added the TCP/IP port for the AWS broker. Really unclear as to what Name/Address to use, as well as the port and if I need to use TLS. I am thinking I do since the device I am using I had to copy the TLS Security certif
268
JWK posted Jul 7 '24 at 11:10 am
Hi Everyone,
I’m a student at a German Uni working on a project with VT Scada. I’m curious to know how one can check/know how much data is being logged and stored in VT Scada.I’ve read the user manual and watched multiple videos, however I’m yet to find the solution. I would really be appreciative for any guidance.
Thank you.
583
I'm trying to communicate between the Allen-Bradley MicroLogix 1100 and VTScada.
I did the following procedures:
I created a Context TAG with the name of my PLC;
Then, within the Context TAG, I created another TCP/IP tag;
In the TCP/IP TAG I entered the Address of my PLC and the Port: 44818;
Within the TCP/IP TAG, I created the Driver TAG and selected the Rockwell Allen Bradley Devices D
recent by TomE  ·  Jul 24 '24 at 3:01 pm
192
In the Bottom Left is a navigation widget made with Page Buttons. In the picture, the "Digster" page is opened.
My question is:
Is there a way to highlight the background of each button when the particular page is loaded on screen?
For example, in this cases, the "Digester" button is clicked and "Digester" button is opened. So the Page button should have a different background color.
6694d69167dfc
recent by Tames  ·  Jul 16 '24 at 3:50 pm
137
jbward8 posted Jul 11 '24 at 5:41 pm
I am trying to create a new tag that totalizes a tag based on month. (I dont want the last 30 days, but the total for January, February, etc.). The specific tag that I am using total pieces of production for a 12 hour shift. I need to totalize that tag to see the production for that month.
225
J_Hob posted Jun 7 '24 at 3:53 pm
Hi All,
Does anyone know if it is possible to move a current string tag value to another string tag?
I have tried to multi-write tag... it allows a constant to be written to a string output tag but not another string tag value to be written to a output tag...
Any help would be much appreciated.
206
this is my poorly written chain of IfElse conditions(I also tried in ternary operator)
https://smalldev.tools/share-bin/IjBFXr6C
screnshot:
My text editor says: 402 lines 26802 characters, which is below the max limit mentioned here in the docs
The maximum length of an expression is 65535 characters.
If your expression approaches this limit, you should consider
667cfd4ce90a3
490
Narciso posted Jun 27 '24 at 12:21 pm
Question: How to change the message that appears in the confirmation pop-up when the "Confirmation dialog" is enable in a button?
This is the default message:
"Are you sure you want to change the value to Running?"
This is what I would like it to say:
"Are you sure you want to issue this control action?"
What is the procedure to change the confirmation pop-up messa
667d4a66efc63
recent by Narciso  ·  Jun 28 '24 at 4:57 pm
1 ... 567891011 ... 38
