156
MatrixDS posted Jun 5 '25 at 12:31 pm
I am looking for someone who is willing to share an application with scripting examples, with the values being passed from multiple tags to the script and out of the script to multiple tags. I have looked on help files but this is not clearly defined, or am I missing something? Tried something like Scope(VTSDB, "FullTagName"\Value but it is not passing and processing the values. Intensionally mi
recent by MatrixDS  ·  Jun 5 '25 at 9:00 pm
179
lamr posted Jun 3 '25 at 3:07 am
VTSCADA manual shows ODBC SQL query to access VTScada data from an external application like PowerBI, Python etc with explicit timestamp. e.g.,
SELECT Timestamp, 'ModDriver1:ErrorValue' from History
WHERE Timestamp BETWEEN '2014-03-01 16:54:00' AND '2014-03-01
16:55:00'
I need to write query using relative time without using explicit hard coded timestamp. i.e. timestamp between last 1 hour o
recent by TriJim  ·  Jun 5 '25 at 6:53 pm
133
mgleb posted Jun 2 '25 at 9:18 pm
When I copy and paste an image, such as a pump or valve, certain portions get cut off. This occurs seemingly at random; sometimes it works perfectly, and other times it does not.
Has anyone else experienced this?
683e06c030bad
224
tldr: openpyxl dont work, pywin32 works. My question is why?
Openpyxl way =>
import os
from openpyxl import load_workbook
wb = load_workbook("./exported_from_vt.xlsx")
ws_context = wb["Context"]
ws_context.sheet_state='visible'
r = ws_context.max_row+1
ws_context.cell(row=r,column=2, value="Asia22")
ws_context.
683a897d6db6d
133
I've spend a little too much time on trying to figure out how to derive "Comms Loss" alarm from my Driver/Port settings using VT. I can see the value changes from 0 - Healthy to some other values when disconnected.
However, I couldn't figure out how to derive a simple "Comms Loss" tags from the system.
Any Advice would be welcome.
67c87710e320b
recent by TriJim  ·  May 30 '25 at 11:55 pm
248
mgleb posted May 7 '25 at 4:36 pm
I am attempting to use the GetAlarmStat function and following the documentation, but I want to retrieve alarm counts for the entire system, so I'm leaving the tag area blank. Has anyone tried this or can someone tell me what I might be doing wrong?
Function in use:
\FunctionLib.GetAlarmStat(\Root, "ActiveCount" )
I have also attempted to self-scope as the tag, but the res
recent by mgleb  ·  May 23 '25 at 4:49 pm
105
Is there currently a way to enable dark mode in the Tag Browser?
If not, is this feature planned for a future update?
I’ve noticed that the Alarm Page supports dark mode with just a button click, which is great. It would be really helpful to have a similar option available in the Tag Browser for better visual comfort during extended sessions.
Thanks in advance!
124
Main [
If Latch(AbsTime(1, 5, 0), AbsTime(1, 1, 5));
TagObj3 = Scope(\Code,"Fq");
ScriptObj\Value = TagObj3\Value;
{this works, changing TagObj3 value in VTScada Tag Manager reflects in the Script tags value.}
TagObj3\Value = 5434; { this do **not** work, I cannot see Fq tag changing its value to 5434 }
{ Is it changing its value to 5434 but o
136
I'm trying to figure out how to bulk generate/edit tags, and got stuck here.
It seems for every new tag, vtscada generates its own custom hash ?
I tried to use python to generate some random string, but faced error as shown in picture.
Tag name found that doesn't match tag file hash
What is tag file hash, how to generate it.
68246fe9d2930
210
Attempting to connect to HiveMQ Cloud MQTT Broker which requires TLS. I've connected to other MQTT brokers that didn't require TLS with no issues. I've created an MQTT Client Driver and created a TCP/IP Port child. None of the TLS settings were successful so I download a pem file from HiveMQ, converted it to a crt file using OpenSSL and imported it to my PC but it does not appear in the list o
220
I am currently working on a project that requires integration with IEC 61850-compliant devices (such as protection relays, transformers, and switchgear). I noticed that VTScada does not have native support for IEC 61850 drivers. Can you provide any information on whether Trihedral is planning to introduce an IEC 61850 driver in the near future?
Alternatively, are there any third-party soluti
157
Dear Sir,
We have OEM SI license. We want to remote changes at our customer site without going to go to site, staying at the office.
We found out in VTScada catalog like this.
Integrators with OEM licenses can securely VPN into a customer's system to fix problems or add functionality without the need to travel to site.
Could you please explain more details about it? Can suggest s
recent by admin  ·  May 5 '25 at 5:33 pm
215
When the user looks at the trend curve, he wants to see the two identification lines of high alarm and low alarm, and when the user looks at the temperature for a period of time, he can clearly see whether the data is abnormal。
See picture
In subsequent versions, can the function of alarm identification of graphs be added?
Than you
6805f9d0df281
recent by Vic  ·  Apr 25 '25 at 8:03 pm
210
Hello, I am new to using VTSCADA but have experience with SCADA software in the past. For our application, we would like to utilize VTSCADA to create data driven maintenance packages utilizing Maximo to create Work Orders.
An example of this application is:
HVAC filter dp is monitored and there is currently an existing job plan in Maximo to do the PM to replace the filters. VTSCADA would
recent by Vic  ·  Apr 25 '25 at 7:48 pm
117
Hi
I have a query regarding copying the trend data. We are using VT Scada version 11.1.21 and want to copy trend data from drive C to other drive in the same PC, to empty the space as our C drive where this application is installed is full now. Anyone please let me know how can i perform this activity safely without facing some serious problems on running application.
Your prompt respons
182
mpetruskavich posted Apr 1 '25 at 7:32 pm
Hey everyone,
Implementing a totalizer in a VTScada application at a wastewater treatment plant (no pulse output on the flow meter unfortunately) and I'm wondering if there's any way to initialize the totalizer with an initial offset as the onboard totalizer on the flow meter will have accumulated a flow total as it's been running for a couple weeks now. Worst case scenario, I could record th
214
Hi all,
I'm implementing alarms in VTScada at a water treatment plant, but I'm facing some problems. I want to set up alarms to occur at certain threshold values and notify operators via email. But I'm not certain on how to correctly implement alarm priorities and ensure proper notification is being sent.
Here are my queries:
What's the best method for configuring alarm priorities in
137
J_Hob posted Mar 19 '25 at 7:21 am
Hi All,
I am having an issue with a daily report that i have configured.
My understanding is that a daily report is a sum of the values accumulated for a each of a selected set of tags within the time period you specify.
Very simple i have four tags which values change approx. 4 times a day, in theory these values should be added together and displayed as a 'Daily Total'... Right?
67da704e08294
recent by J_Hob  ·  Mar 19 '25 at 11:56 am
85
TomE posted Mar 9 '25 at 9:39 am
Client has an existing BMS system which they can configure internally. They would like a VTScada system to send info (live tag values) to the BMS so security can view if an alarm is active out of hours.
I could not see any drivers or info in the help. Are there any tools that enables VTScada to act as a EtherCAT slave, or will we need to put a gateway in (Modbus TCP to EtherCAT slave) to fac
143
RayJS posted Mar 5 '25 at 4:08 pm
Hi, Has anyone setup VTscada with an AB SLC505 over ethernet. I am struggling with understanding the configuration and receive either a 789, 3894 or no value. What would be the correct setup config for a SLC505 with IP address of 10.7.112.61.
Tried different PLC modes,Port segment paths and CIP targets and tried 44818 or 2222 TCP/IP port number each result in a error code. I can ping the add
recent by RayJS  ·  Mar 5 '25 at 7:44 pm
219
Hello everyone,
I'm working with VTScada to read multiple variables from a PLC via Modbus RTU. When reading digital inputs, coils, or bits (using Modbus function 01H), the PLC requires that they be read in multiples of 16 bits.
In VTScada, I use "I/O and Calculations" tags to read these variables, but I haven't found any option that allows me to read multiple bits at once.
I would rea
120
Need to enroll my users using SCADA to Entra Office 365, this creates a new profile at computer. Will users settings and licenses work afterwards? Same computer. SCADA was installed locally and will be on our network which creates a new profile for user.
recent by admin  ·  Feb 24 '25 at 12:47 pm
12345678 ... 38
